Katech 427 LT1 - The highest horsepower NA Gen 5 LT1 in the world. 703hp/625lb-ft
Premium Supporting Vendor
I'm pretty sure I can make that claim. If there is a higher one somebody else has done on the engine dyno please let me know.
Full specs to be released later, but here are some:
703hp/625lb-ft on 93 octane
4.070x4.100"
Callies forged crank/rods
Katech forged pistons by Mahle
Katech LT1 piston squirters
12.5:1CR for use with premium pump gas
DI
Katech AFM delete valley cover
Katech CNC ported heads
Very streetable camshaft. Same or better drivability than K501.
Two all new, not yet announced products:
Katech throttle body
Katech 4 stage dry sump system
-Manufactured exclusively for Katech by ARE.
-Features OEM internal pressure and scavenge pump plus
-2 stage external roots pump
-New pan casting with better windage control
-Screened pickup fittings
-In car mounting will vary from what is seen in the photo
4.070x4.100"
DI
Quite a lot of numerical difference between peak HP and peak TQ.
Jason, how does this compare to similar ls7 engines you have built? By similar I mean camshaft and compression. Wondering what you think the di and vvt are worth if anything.
A similar LS7 camshaft/compression (12.0:1) makes 660hp. We are getting a lot up top with cam phasing.
