Zip Corvette C7 lowering bolt install.
Old 01-26-2015, 01:21 PM
MIGHTYM0USE
MIGHTYM0USE's Avatar
Default Zip Corvette C7 lowering bolt install.
I got the set for $60. Zip is less than 3 miles from my work
http://www.zip-corvette.com/14-15-lowering-kit.html
I was not able to find any info on how this has been done (without a sawzall); So here we go.
For me the front lowered to an ok-for-now amount on the stock bolts so I started on the rear. I expect the front to be similar if not easier.
Raise the car; Pick a side, Remove the wheel.
Remove the shock completely. 15 upper and 21mm lower
Remove the 4 13mm bolts and 2 plates holding the leaf in place
Remove the toe rod from the spindle, 18mm and I forget the allen 5mm-ish.
Remove the sway bar link from both sides to help the arms lower, 18mm and 10mm.
Remove top Spindle nut, same 18mm and 5-ish allen head, will require a tap to pop free from upper A-arm
I ended up needing to remove the opposite shock (lower bolt only) to free up the leaf entirely.
Out comes the leaf with a little struggle.
Easy part is swapping the actual lowering bolts 10mm. I drew an arrow on the leaf in case it got turned around.
Going back in..
Final result with rear fully lowered.
This was only a couple hours work figuring out what to do along the way. I'll add tq specs that anyone may want to dig up, I went by feel.
Old 01-26-2015, 03:08 PM
Kracka
Kracka's Avatar
Received 5,716 Likes on 2,921 Posts
Great write-up, appreciate all the pictures!
Old 01-26-2015, 03:40 PM
MIGHTYM0USE
looking to do a PFADT Tri-Y install next
Old 01-27-2015, 06:19 AM
slesher
slesher's Avatar
Thanks for taking the time to document this. Stance looks just right and car looks great.
How does she ride now?
Old 01-27-2015, 07:10 AM
descartesfool
descartesfool's Avatar
Nice DIY.
Old 01-27-2015, 10:58 AM
MIGHTYM0USE
rides same far as i can tell, the spring rate doesnt change or damping, just ride height.
Old 01-27-2015, 11:05 AM
Kracka
Kracka's Avatar
Ha! I'm with ya buddy, looking forward to your results and documentation too
Old 01-27-2015, 11:36 AM
slesher
slesher's Avatar
That's great to hear. Adding to mod list. Thanks
Old 01-27-2015, 03:32 PM
Mr Guns
Mr Guns's Avatar
Thanks for the write-up! I might tackle this one day in the near future.
Old 01-27-2015, 10:39 PM
slesher
slesher's Avatar
Thanks. Btw what is the distance between the tire and body at this point?
Old 02-21-2015, 06:11 PM
mrbdas
mrbdas's Avatar
see your in Richmond an I'm in Portsmouth so guess i drive up there in you can help me J/K
Old 02-21-2015, 06:51 PM
LT1xL82
LT1xL82's Avatar
NICE garage/equipment/car/post! Thanks!
Old 02-23-2015, 09:20 AM
MIGHTYM0USE
i wish i had time, already swamped with other side work!
i measured this and remembered thinking i should photo because i would forget.. and i was right!
thanks very much. I can really appreciate the facility growing up without, and the maxjax lift was simply made with the corvette enthusiast in mind. worth much more than the $1950 i paid.
Old 06-24-2015, 05:58 PM
Q8 c7
Q8 c7's Avatar
Great oics & hopefully tomorrow we can do it, is the pics or a link on how to install the front lowering bolts? Many thanks
Old 07-02-2015, 11:41 AM
MIGHTYM0USE
if/when i get around to doing the front ill update this thread
Old 07-03-2015, 07:30 AM
C7Kevin
C7Kevin's Avatar
excellent job !!!!
wrench sizes and great photos really make clear what you are doing.
should provide a good comfort level to anyone contemplating getting
their hands on wrenches for the first time in a while.
Old 09-29-2016, 08:28 AM
ninety9ta
1st Gear
ninety9ta's Avatar
This looks like a great write up. But it appears the photos are no longer available. Any chance you could share the pics again? I tried to tackle the new lowering bolts last night...
To Zip Corvette C7 lowering bolt install.
Old 09-29-2016, 11:06 AM
MIGHTYM0USE
they are no longer online, sorry!
i have a couple if you need via email
Old 06-24-2017, 11:37 PM
zdr2k
zdr2k's Avatar
Did mine today - no helpers just me. It is better to do if you have a helper. Took about 7 or so hours.
The rears are easy compared to the front.
The drivers side upper ball joint wouldn't budge. Had to remove the A-Arm. Getting an alignment anyway.
I'll post more details tomorrow. Super tired now.
Beer time.
Old 06-25-2017, 01:03 AM
Maxie2U
Maxie2U's Avatar
Received 4,166 Likes on 2,250 Posts
Can't see pics?
Quick Reply: Zip Corvette C7 lowering bolt install.
