Anybody Else Having Issues with Diablosport Tuner
Sorry for the delay, I did try and load the 93 octane tune on top of the 91 octane tune. The tuner already saves the stock tune incase of a restore so I wasn't concerned that I didn't have it. I do not believe you have to load the stock tune before loading another tune.
Still trying to get a hold of Diablo to discuss with them and get their take.
I didn't want to ask too many questions at the dealership about the TCM. I was just happy I didn't have to pay to replace it!
Supporting Vendor
__________________
Mike Litsch
DiabloSport/Range Brand Manager at Holley
Trinity T2 and inTune i3 now available for 99-19 Vettes!!
Subscribe to our YouTube Channel!
Mike Litsch
Hey Mike.....
I had spoken to Garret when all this happened. I sent him a few emails but got no response and tried calling and no one picked up.. I did call later in the day mountain time so you may have been closed already. I can try and call again today. I really need to know how to reset my tuner? I haven't plugged it into the car since the initial try that fried the TCM. I am guessing the tuner is still in recovery mode. I just didn't want to plug it in without first talking to you guys.
Supporting Vendor
Hey Mike.....
Supporting Vendor
I tried to install the 93 octane tune without any other changes and it ended up being unsuccessful and when it was in the process of installing the original tune it failed and would keep giving me the message that the tuner could not find the PCM to make sure the key was on. The dealer said that there was something wrong with the PCM but they were not sure what was wrong. They replaced the PCM luckily under warranty. I tried installing the tune again and it installed without issue. I am now in AZ and 93 octane is not readily available so I tried to install the 91 octane tune with the modification of removing the top speed. This again fried the PCM and the dealer here replaced the PCM again under warranty. I am following the instructions to a "T" however generic they may be and have had issues with my PCM twice. While installing the tune it would fail when writing to the TCM. I sent the tuner off last week with an RMA to see if there might be something wrong with the tuner.
P18c9 is a generic manufacturer fault code that can be detected and cleared by the Tech-II. If a tech suspects that the ECU may have been altered, they will pull it out and send it to the engineers in Milford, MI. It will take them about 5 minutes to identify it is not "original" and poof, your warranty is history and you're on the hook for repair costs. I've seen this happen to a C6 ZO6 and recently to a C7 tuned with the inTune. Caveat emptor!
Dont be surprised that if there is a third pcm failure , GM digs deeper for the cause , and voids your powertrain warranty when they pick up any indication of a tune....
I had the first ever Diablo Predator handheld released for Corvette; loved the device.
As new model tuners are introduced, they tend to spend time adding features to these tuners, and advertise what now they can additionally do.
I can only suggest that Diablo spend as much adding to what it can do.... as making sure there are things their device should never do. It should never cause a problem that it can't recover from itself.
never.
I have no doubt that Diablosport will correct this. It's just that this "bug" should of never of been allowed to have happened in the first place. If to load a higher octane tune requires the car owner return back to the factory tune first; then the tuner should not allow you to do it any other way (safeguards built in).
#33
Supporting Vendor
Was the car modified beyond the tune? What was the nature of the failure that lead to the warranty claim to start with? Please dont just drop some 3rd hand info with no more facts to back it up, I understand this is the internet but that doesn't make it right.
I am sure they did not see anything in the pcm that lead them to prove it had been flashed by one of our devices.
#34
And; they will be able to determine this via close technical inspection of failed PCM, or simply by reading about it on car forums...
#35
Supporting Vendor
How do you figure?
Do you want to know how many times I have seen Tech2/MDI fail a flash?
There are no guarantees in flash tuning, errors are to be expected, and we leave nothing behind that will tell them we were there, so even if they identify it as a flash failure, it could have been a flash from an MDI for all they knew.
#36
How do you figure?
#37
Supporting Vendor
No offense, but I take that reply to mean you have no further info to back up your claim.
If you feel you have some info that we have overlooked in our years of development on GM PCMs, please, feel free to share it with the community, I am not against debating it openly.
Other than that, you're one more guy who heard from a friend who knows a guy at a dealer who swears they can see anything....and that's a disservice to the community IMO.
#38
#39
St. Jude Donor '14-'15
There's a reason we're still reading/writing these at a max of 115200 baud - there's no room for any uncorrectable errors.
#40
Odd that we have not heard from the C7 owner. (Or the C6Z)
The point I'm trying to make is this, you say Chevy cannot tell if a car has been tuned with your unit and returned to stock. That's simple not the case.
