Tire Scrub
Tire Scrub
When slow turning with a 2014 C7 and steering wheel is turned full right or full left I often feel what appears to be the tires scrubbing sideways on the street. Is this normal because of the tire width or is something defective?
It is normal b/c of the 7.0 degrees of caster in the front end alignment.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes
2015 C7 of the Year Finalist
Shows why the tire snap happens.
Elmer
I've seen this animation before and it definitely helps to understand what's going on. But perhaps the bigger question is, why did GM designed it this way? I can't remember any other vehicle I've owned that have had this slow steering issue.
Yes, but many, who are new to the the community (and this gen), don't know this.
You may have seen the subject come up many times and are tired of it, but most likely, the OP hasn't.
Frankly, this is one "smilies" or emotcon/imoge that could be done away with, IMO, because it does nothing but promote belittling. No one who posts this adds anything of value to the conversation.
Don't get me wrong, I'm one of the first to quip in with a sarcastic remark, but I' also one of the first to step away when I realize it has gone beyond friendly ribbing.
Virtually, 100% of those who post the poor unfortunate equine, should just not respond, and go to the next thread that might have some relevance to them.
I've read a lot of posts about this issue, and understand what's going. Typically responders post a graphic, or the name of the condition, and state it's a normal condition. That's all fine but never have read anything about why GM designed the steering this way. Was there some handling trade-off that had to be met? Or perhaps just the characteristics of the geometry of the steering components at extreme steering angles? I'm not bitchin', just curious.
It's called the Ackermann effect. As shown in the illustration above, it's due to differences in steering linkage speeds... it is easily fixed through modern steering technologies however Corvette engineers have chose not to because the car actually handles better at higher speeds the way it is...and they deemed that as more a priority.
Yes, it is.
It is easily fixed by using toe-OUT--however this makes the car nervous in the straight line.
The Vette actually goes around corners faster with a bit of toe-OUT, but few drivers would put up with the nervousness. Most race cars use toe-OUT in order to minimize scrub in turns and thereby get rid of a source that heats the front tires. After getting rid of this source of heat, the camber can be adjusted for more grip.
All at the expense of nervousness in a straight line.
<snip> it is easily fixed through modern steering technologies
I posted this on another thread, one of many that asks about the symptom.
Perhaps just another case of: "a little bit of knowledge is a dangerous thing."
But, I can't help but wonder if the "ackermann-caused" tire hop issue on C7 Corvettes is a predictable byproduct of Chevrolet's desire to provide the exceptional turn-in capabilities that many have raved about.
I am happy to be proven wrong about this, but, until then, I think that the "hopping" is just a price we pay to enjoy fabulous turn-in on the C7s.
I believe that the type and amount of Ackermann employed in the C7 steering geometry was employed by Chevrolet to produce the great turn-in that C7s have.
I have a 2015 C7 Z51 coupe and I just LOVE the steering in general, but particularly the fabulous turn-in the car has. It's nothing like any car I have ever driven.
