How to raise the C7 a couple of inches?
My brother in law likes the c7, but he is 71 and has trouble getting out.
Does it use transverse leaf springs? What do you suggest?
Know a shop in Las Vegas? Can dealer do this?
Thanks!
Thanks!
Raise a couple of inches? If he's really having trouble getting in/out of the vehicle, this probably won't get better over time. Hate to say it, but a Corvette simply may not be a practical vehicle at this point.
He has no trouble getting in/out of my 72 c3.
the seat is 16" off the ground.
What is the height of the c7 seat?
Can anyone tell me that? Just put a broom handle across the seat, and measure to pavement. subtract side bolsters if they get in the way. Thanks!
I do see where guys have installed longer bolts to lower a c7, so shorter bolts and a wheel alignment might do it.
Maxing out the stock ride height bolts will raise the car by 0.5-1.0", and if he gets the 2/3LT model those have power "easy exit" seats that lift up when you open the door.
he had owned c3c4c5c6, CTS, and now MB retractable hardtop. no trucks
My dad (leg problems, replacement hip, etc.) can get in & out of his C6 and my C7. A little more hassle than a standard sedan, but he says it's totally worth it!
St. Jude Donor '14-'15
Another possibility (assuming they can support the C7 platform) is an AirRex suspension.
I've seen a few of these on cars, and it's essentially fully adjustable air ride suspension. It's neither inexpensive nor difficult to implement, but there are several C6 examples with such a system.
It appears that the C6 and C7 are unlisted, but there are examples out there. This would most likely mean he would need a base (non-MRC) suspension to start out with.
Does anyone know what the stock ground clearance of a C7 is? Does it vary by year, and are grand sports lower than base models?
Received 8,918 Likes
Bill
Well for entering or exiting his C7 at home, he could put 4 - 2”x12” (angle cut on the leading edge) boards on the floor to pull up on in the garage/driveway. At least it’s a cheap way to solve half the problem?
