Drag Radials for a 19" wheel
What size and what brand is everyone running on the stock 19" or 20" rim without the tire rubbing? Any help will be appreciated.
Received 2,379 Likes
305
tsw sticks out too far
If this is a drag strip only set up, it won't matter. If you are running drag radials on the street all the time, get a proper offset. Stock rear is +79. I think TSW is about +67 which almost 1/2" too far. (A 25mm difference is 1 inch)
A somewhat ill advised proposition is to have the backside of the wheel mount face machined a little to effectively increase the offset of the wheel. You'd have to ensure caliper clearance and only take off a little bit of thickness. I've seen it done but it's not exactly a quality way to approach mounting wheels.
I would consider stepping down to a 18" wheel... These 19/20 wheels combos leave a lot to be desired when I comes to purchasing tires. You need sidewall for traction...
Supporting Vendor
A well prepped car can fly on them....don't let the stangs take all the glory!
http://www.svtperformance.com/forums...over-4-100-lbs
http://www.svtperformance.com/forums...-GT&highlight=
The car on 20's got daylight under one of the front 20's at Bradenton last week Thats hook!
This is my brother car which is for sale under the forsale section but he had 19 inch radials in this car.
LMR- Worlds FIRST 9 Second C7 Corvette!! - YouTube
Supporting Vendor
i'd like to see some of the radial races hold a street tire class for radial cars running 19-20" wheels, there would be some awesome racing!
If my track doesnt reopen soon I will be selling:
18x11 Forgeline GA3s +77 offset with Mickey Thompson Drag Radials 305s (0 passes)
18x4 Forgeline GA3s with front runners (M+H?) - I think Ben@WeaponX put a few passes on these but they look brand new.
My track closed at almost the same time I bought these wheels and tires so I have not been able to use them.
Not for sale today, but maybe very soon!!
