--RELEASE-- LG Motorsports C7 Corvette Billet Drop Spindle
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
--RELEASE--
LG Motorsports is proud to introduce our latest Corvette suspension component, the LG Billet C7 Drop Spindle!
These spindles will allow you to lower your Corvette 1 full inch over stock while maintaining correct control arm geometry and shock travel. Now you have more room to play with on ride height adjustment on your factory leaf spring, or choose our G2 coil over kits for even further adjustments!
These are especially great for those with the magnetic ride shocks, as you can now have more height adjustment without disrupting your shocks or height sensors!
MSRP $2995.95 for the set of four
Dealers welcome
- 1" lower than stock
- No loss of shock bump travel
- No loss in proper control arm geometry
- stronger wheel bearing mount
- stronger brake caliper mounts
- less deflection on track
- Retains all OEM mounting points for brakes, bearings, sensors
- Bolt on install
- Lower center of gravity for increased performance
Dealers welcome
That is a great price and I'm not one to complain but sure your not missing a number in there?
The cost on the ball joints is probably 1/4 of that price.
It is wrong. They have drop spindles on eBay for $2995.00.
Former Vendor
Installed a set on our C7 Z07 package car.
Ride height dropped one inch with no other modifications. You can lower the Z07 cars another 1/2" front and 5/8" rear on the stock adjusters, or raise slightly as well. The Z06 (non Z07) cars have almost 1" front and rear to lower the car over stock (due to spring change between the cars I would assume).
I have more sets shipping to customers now.
Former Vendor
Bone stock C7Z51 compared to our C7Z06 with LG drop spindles and lowered on factory bolts (as low as it can go without coil overs).
Tron1 (06-27-2016)
Former Vendor
Dave at ForgeLine just installed our billet drag spindles along with a awesome set of ForgeLine AR1 one piece monoblock wheels on his C7Z!
Former Vendor
'Performance Corvettes', one of our dealers, just finished this C7Z today with our spindles and aftermarket lowering bolts.
Former Vendor
Look for a full write up coming soon with Corvette Online and Turnology!
http://www.corvetteonline.com/
Received 1,762 Likes
Former Vendor
Those of you on the HotRod Power Tour can see some in person along with some killer ForgeLine wheels.
The ForgeLine C7Z06 is on the tour right now so be sure to stop by and talk to Dave and check out the car!
