2014 Rev Match update for M7?
Does anyone know if there is a Rev match programming update for the 2014 M7 available? The 2015's Rev match feature is very aggressive, functions much more efficiently, and is quicker to anticipate gear changes.
I turn the feature on about 50% of the time so an update would be awesome.
Searched around and put some calls in but haven't heard back from anyone yet.
Thanks in advance.
Thanks in advance.
Someone please correct me if I'm wrong, but GM is known not to update software like that. ie: putting '15 software into '14 car to have the updated benefits. It's their way of saying get a '15 if you like it that much.
I'm hoping when '16s come out, if android auto and apple carplay is introduced they would update my '15 software. but they never do stuff like that.
sooo, probably out of luck buddy
This would be really nice! I like the ARM feature, but it is just a little slow on the '14...
It's not slow, just not as "instantaneous" as it could be, which it sounds like was improved upon for the 2015.
Interesting, I haven't heard about this yet. Could this be something a tune such as Diablo could implement? Should be as simple as copying that section of programming from a 15' if that's something they can access and change.
Received 2,379 Likes
can be altered in the tune
St. Jude Donor '14-'15
We can update them to a point with the MDI, but the checksums have to match up for the 2014 or you get a brick.
Higgs, can you post or send me the tables (names) for that in HPT or EFI-L? I didn't see that in there, but now I'm interested since I friggin' hate my ARM. It's obnoxiously slow - on my car, it just sounds like I'm being an *** and revving to be noticed. I have to turn it off unless I'm on back roads. It's not even as quick as heel/toe - I know, we all proved that wasn't true, but heel/toe is smoother than the jerky ARM.
Wasn't aware that had changed for '15, but would be delighted to find a table in there.
Granted, mine is from the first week of production (first 500) and has had a lot of updates. I'm just excited to hear about something being in the adjustment parameters to 'fix' it.
The 2015 ARM gives you a run for the money and is very fast. Almost feels like driving a different car altogether.
I'd have to say slow and not extremely accurate. It was a neat novelty for the first week, and became very tiresome after that. It over-revs, does it too slowly, and ends up still not matching correctly to the point that you get slip. Maybe it's fine for stock, but I drove it twice before supercharging it, then another 200 miles before going all-out. So, it's just obnoxious now. No need to super-rev to 5000 for a 3->2 downshift. Just draws attention and makes you look like a tool for being that loud. Blipping with heel toe is just that - a quick blip. I assume that's how yours is. This one just holds the throttle even through the shift...
Still use the ARM on my 2014 (born in June I believe) in traffic since it doesn't over rev too much at slower speeds. On back roads and slinging around its more fun to heel/toe myself...no pun intended
it is a perfect match though. there is zero slip when you change the gear.
Crazy that the entire year was like this. If it's just a calibration change, that's not hard to implement. Perhaps saying it's a tool to push the '15 is correct - always has to be a newer, better implementation - a la Apple.
Looking forward to getting that fixed. Got word today that it is, indeed, fixable with the tuning in HPT.
I will certainly let you know how it goes. Car is parked (across the entire garage) for several upgrades, including a fuel pump, lots of wiring, and a whole laundry list, so it may be a week or two before I get back out and have some impressions.
I wish I could relay the info on how to handle it, but my tuner is taking care of it for me as I'm running a hybrid/mixed tune platform setup. I'm guessing it's either a custom OS, or close to it.
Anyway, my knowledge stops at HPT tuning - if anybody knows how to fix this in HPT, post the table name and I can put up some screenshots, etc.
