What kind of RWHP to expect?
Anyone do a baseline of an A6?
Also, what should I expect for rwhp for an A6 with ECS (8 lb plate) and Meth?
Can you run no restrictor plate safely with stock injectors, fuel system, etc?
Thanks for any input!
were running without the plate and hit about 11.5psi boost peak and making 690rwhp sae corrected with the a8 on our mustang dyno
setup consists of
-ecs novi 1500 kit
-arh 1 7/8 lt headers
-alky control meth kit
We have about 1500 street miles with alot of abuse and about 30 track passes and couldnt run better..
If you are looking to add meth i would say no restrictor and keep the tuneup safer
,Matt
jtmmotorsports
setup consists of
-ecs novi 1500 kit
,Matt
jtmmotorsports
setup consists of
-ecs novi 1500 kit
,Matt
jtmmotorsports
setup consists of
-ecs novi 1500 kit
,Matt
jtmmotorsports
I kind of want to start with the restrictor plate and work my way up... curious to see how the drag radials do with 8lbs and meth.
You should be around 600 to 625 depending on the Dyno. I ran mine for almost a year with 8psi and a meth kit before I finally went the full shebang... But you will be very happy. Nothing wrong with baby steps, start with that then add on as you want more power.
Wow! That's extremely impressive for just blower, lt's and meth. I'm hoping to break tens, time will tell.
