I want to install a train horn in my C7.
Thanks Dana......I'm on a HUGE Camaro Forum (Camaro5) where I posted those in the DIY section with the video....its had a hair over 41,000 hits. and a number of the guys there got one and used my DIY.....even one of the guys in my local club did it. The best part in my opinion is the fact that its 50 State Legal...and can be a LOT of fun when you creep up behind someone that's not paying attention in a parking lot at a car meet! LOL Not to mention it really works good on the road!
I know this is a grave dig here, but we are doing the Hornblasters Conductor 228V kit on my C7 this weekend. We found out inside of the engine compartment closest to the passenger side door, there is more than enough room for the entire kit to go. I will post pics after the install.
There are fools that install these illegal devices on cars and trucks. I enjoy calling them into the police when I see some boob blowing it.
If you were to cause an accident or death by using the horn you will be in jail and broke lol.....
Cause an accident or death? The only accident or deaths that I have encountered are semi drivers not seeing me on the interstate and not hearing my horn when they decide to lane change abruptly. These are just as loud as the horns they have on their trucks so I don't see the problem.
EDIT: Also actually headed to Tampa as soon as we finish the install this weekend if you'd like to check it out.
I've installed Wolo air horns in all my vehicles
Not a true train horn but pretty dam' loud. There's lots of room in the front bumper in the C5; I suspect it's the same for the C7.
I'll post a full write up when I'm done. Doing the ALP Laser jammers at the same time as well. Based on measurements and everything we checked out this kit should fit very safe and snug in the engine compartment. But, obviously with any build I'm sure we'll run into speed bumps. I'll keep everyone posted though.
There is a guy near where I live who makes replica train horns. And these sound EXACTLY like legitimate train horns. As in the exact sound of a specific engine type, which you get to specify. They are MUCH MUCH cheaper than a real train horn.
St. Jude Donor '14-'15
I still respect the idea of doing the whole big thing, but it's hard to find space in these cars. Certainly will have the surprise factor, though, since most are in huge trucks that you half-expect it to come from.
Since it sounds like you're using this legitimately (like for an area like mine with small Interstate highways [I-40, I-55, & I-70]), I don't have a problem with it. We have so many deaths here from truckers not obeying the rules that Highway Patrol has a huge semi-truck task force just to pull them over, and they stay busy 24/7.
The idiots that do it for the YouTube factor... That's something different.
#33
I did something similar on my Wing. I got so tired of people in cars ignoring/not-seeing me and the pitiful original horn on the bike did nothing to attract attention.
After I added the air horn, no one ignored me again. One time some idiot was not paying attention to the road and began drifting over into my lane. One long HONK of the air horn startled the driver so much, he jerked his wheel to far the left and wound up hitting the median barrier.
The Stebel doesn't have a hose....the compressor plugs right into the horn. Some motorcyclist do separate the Stebel horn and compressor due to space limitations and buy a hose to connect the two...but as is it works great.
This horn has been painted wrinkle black to match the Night Train's paint scheme.
#34
#35
Easiest way to install is to pull front edge of drivers side fender liner to get to stock horns. Hook the relay up to them and mount the new horn in that area also. Ran the relay hot wiring to the positive post on the back side of the fuse box and the ground to one of the grounds near the steering box. This horn + relay was under $50. total, has a compact compressor built in, and is JUST LOUD ENOUGH!!!!
#36
I get on real trains everyday work day. A train horn is no joke and does not belong on your C7. You would get in trouble.
The C7 has a good horn!
#37
although you tube videos don't truly do these things justice......but there is the one in my Camaro. and it shows the difference of stock and with the air horn.
#38
How about 20 12 inch piston's.
The air Volume is HUGE. Real train horn on a train I would wager are louder that than your example.
Real train horn is not fitting in a C7 either
#39
#40
Dana.....Not a Video.....but a step-by-step, with lots of pictures through the entire process, not to mention a COMPLETE list of every single piece/part needed.....and where to buy the kit. just have to keep in mind that it is specifically tailored for the 5th Gen Camaro.
Here it is: Attachment 47873262
if you have any questions at all don't hesitate to shoot me a PM.
