HOW TO: Z51 Brake System Upgrade for Base Model Stingray
Can someone tell me the specs of the rotors? Diameter and thickness? Also is the bolt pattern for the C7's 5x120? I have a ZL1 I track and the rotors are really expensive and I'm thinking that this may be an option. I know the C6 Z06 (non carbon ceramic) are 14" x 1.3" cross drilled and CHEAP
Splash Guards
FYI, you may want to replace the base splash guards for the Z51 guards while the rotor is off. The base guards will restrict air flow if you ever install the cooling rings when tracking the car.
AeroJim (05-27-2016)
Just a quick question: I was told (somewhere by someone...?) that the rear brake calipers could be use when changing over from a stock brake system to a Z51 brake set up.
Would you happen to know if that's true? Do the rear Z51 calipers look the same size as the stock ones you removed?
Thanks,
Sal
Thanks,
Sal
I'm Batman..
Pro Mechanic
Thanks,
Sal
Thanks,
Sal
Ant
Would you happen to know the Part Number for the Z51 Splash Guards. I am upgrading base brakes to Z51 brakes.
Sr.Random input generator
Brake Splash Shields
23446730 SPLASH SHIELD, LEFT
23446731 SPLASH SHIELD, RIGHT
I hope this helps.
There is normally a parts diagram with part numbers on these parts sites.
#35
No, however I do have a set of four (front and rear) brand new (never installed) original equipment red Z51 calipers and two rear RacingBrake rotors for sale here under the classifieds that I'd be willing to provide a package deal.
Thanks,
Joe
Thanks,
Joe
#36
I'm in the process of getting the parts ready to do this upgrade to my base Stingray. It appears that left splash shield 23446730 is a discontinued part. Does anyone know the new part number for the left shield?
#38
Thanks for the reply. All of the online GM parts stores show the part in stock, but every time I try to order it, I get an email the next day saying it is a discontinued part and unavailable. I have tried this with 4 different online stores like Trunk Monkey, Tasca, Chevy online parts, etc. with no luck. My guess is that GM changed the part number on the left shield and replaced it with another and the challenge will be to find out that new part number.
#39
I'm Batman..
Pro Mechanic
#40
Yeah, I'm stopping by my Chevy dealer today to get the part number. I'll post the updated part number in your thread for future reference for those who do this upgrade in the future. Thanks for the how to thread btw.
