Corsa Extreme Mufflers
Are the Corsa Extreme NPP mufflers smaller and lighter than the stock NPP mufflers?
I don't believe they do. If you have factory NPP, the Corsa's, I believe, will keep the AFM but not the NPP functionality. You will zip tie the NPP valves off to the side to keep from throwing a CEL but you will not have an active exhaust any longer.
Billy Boat, Borla, and one other offers factory NPP support. I am not aware of any others.
I would remove the NPP valves and install a connector on the end of the wires.
Trifecta can eliminate the CEL. I bought their unit.
I would just buy the Billy Boat bullet exhaust, except the tips are only 4".
Not sure about the weight but the sound is outstanding! !!
Installing the bullets tomorrow. I have the speedway tips, black. There are four tips. The 1/2 inch isn't going to make a difference in flow or performance. 3 inch pipe will make up for the smaller tips.
Thanx, Its just that the 4-1/2" tips look better to me than smaller ones.
with corsa, you use the AFM valves but bypass NPP connections and no NPP valves. I installed the xtreme and double helix x pipe myself on my non NPP and the sound is awesome. Loud, but not bothersome while driving and makes me want to use paddle shifters more to hear the beauty of the sound.
Tyho, any good pics of BB Speedway tips on your car? I've seen some poorly aligned.
