Issues since being tuned
Ok, as posted in the E85 build thread I received my car back from the tuner last weekend. Since then I've now experienced two issues and am hoping for feedback.
1. When sitting at idle several times and rev the engine (You know you get the car back and of course everyone wants to hear it) the throttle either hangs or continues to climb after I let off. So I either blip or stomp on the gas a little bit and then it will stay at a certain RPM or gradually continue up the RPM range to the point where I shut the car down so it doesn't start bouncing off the rev limiter.
2. I was on my way to the track last night to get a couple passes in. On the way there, the highway was shut down to one lane and I got stuck in stop and go traffic for 35-45 minutes. I experienced the same message as FYREANT in his overheating thread about the AC shutting down and my temp was in the red hovering 255. I have a 160 tstat installed and prior to this ran very cool. Once I got moving the temp dropped significantly back into normal range and then once at the strip in line waiting to get in it started overheating again and I shut it down. I didn't get out of the car, but couldn't hear the fan obnoxiously loud or anything.
I let the car sit for 45 minutes or more. I checked the coolant reservoir and that was normal. I then started the car again and let it run for 10 minutes and temp still under 220. So I put the AC on max and let it run another 10 min idling and temp still just under 220. I was waiting to see if it would overheat to see if the fans were kicking on or to determine if I could tell if the tstat was functioning properly and it appeared fine. Drive home was fine as well and needless to say I didn't run the car at the track. Never threw any codes.
Any ideas? I'll check things again this morning, but of course supposed to rain all day.
A recap of the mods:
160 Tstat
Ported Intake
Ported TB
TSP longtubes
aFE CAI
UPR catch can
tune
160 Tstat
Ported Intake
Ported TB
TSP longtubes
aFE CAI
UPR catch can
tune
I'm Batman..
Pro Mechanic
Did your tuner make any changes related to when the fan comes on? I topped off my reservoir to allow the system to burp and it hasn't happened to me again at this point. Though its only been a week. May want to try that for now.
Received 2,379 Likes
do you have access to your tune? send it to me and I will have a look
I'll have to see. I emailed the tuner about some other cosmetic issues where the sensor plugged into the ECU and haven't heard back. Scratched the side skirt and misaligned the fender to where the passenger door was clipping the fender. I got most of that realigned yesterday. I think my car was rushed out and I'm dealing with the fallout which is totally out of character for this tuner who I previously recommended strongly and only had planned on tuning my cars. It may be time to get HP Tuners so I can data log and do things on my own. My neighbor has it so I could potentially see about buying credits for his license. Thanks for the offer to assist and I'll certainly follow up if I obtain access to the tune file.
St. Jude Donor '08
Your neighbor can download a copy of your tune without using credits. Then send it to Higgs. Credits will be needed if you try to upload changes that Higgs may make. $100 worth of credits is a VERY cheap way to get a good tune.
I'm Batman..
Pro Mechanic
I'm not sure if he made any changes or not. I changed the oil this morning, checked the other fluids, burped the system and went for a drive. I tooled around stop and go sitting periodically and then let it run in my driveway idle for another 20 min and everything was normal. Got out and the fan was running as well. So I took the route you did as well and all is good at the moment.
^^This. Good recommendation.
