Going to drag race my Vette tonight...tire PSI, launch RPM, etc;?
I'm also m7 non Z51 I ran 12.5 at 116mph 60ft 2.3 I coulda ran alot better time if I didn't spin so much also bad 60ft the m^ will get a 11.6 to 11.7 with a good 60ft
If you want better times hold off until late Sept, Oct or early Nov when the air dries out and the temp drops. I don't know where you ran but I'd suggest Old Bridge Raceway at Englishtown, NJ. It's not too far from you and there's a ton of guys running the Corvette Challenge there on Sundays who'll give you a lot of help & hints. Good luck! You should do way better.
2.07 isn't horrible for a stick car on stock tires, I'm sure with practice you can do better but I would just go back in the fall I bet you'll go bottom 12's.
Received 1,296 Likes
2018 C7 of Year Finalist
Must be hot out when you are running. My trap ranged from 114-119 in my stock M7 with high elevation and really ****** DA's. Got better as the air cooled off though, my 119 was my last run of the night.
it was still warm out and i was in the back of the line so by the time i got up to line car was hot
