Going to drag race my Vette tonight...tire PSI, launch RPM, etc;?
I was searching around on here didnt see any info on this yet as there was for the c5,c6 etc;
For those that ran there c7's already how did you run it ?
I am a 7mt z51 stock except for corsa xtreme exhaust (so stock) lol
what PSI did you drop your Rear tires too? inflate the front to ?
What did you launch at ?
traction off ? traction and stability off ?
it will be 40-50 degrees here tonight
thanks in advance for any info !
I knew how I ran my c5z and c6z but each car is diff ! lol
Fill the tank? traction is better then weight here I guess?
so I ran last night 38 front tires 25 rear.
best run was 12.5 @115.xx .. 2.088 (i think dont have slip in front of me) 60'
tank was half full. all my other vettes I used to race with less than 1/4 tank
this one is also 200 or so lbs heavier than my c6z was.
Best launch was the one at around 2-2500 and I slipped the clutch.
other 2 runs I spun (came off the clutch too fast) I am used to running on drag radials versus street tires.
From my experience drag racing my c7 A6 convertible...
Lowering the tire pressure did not help because the runflats have a very stiff side wall...
What did help was a good burnout to heat the tires..
My best time of 12.2 @116.7 2.0 60FT was achieved with traction control off and stability control on.. Spinning the tires only waste time...
If your a good driver, launch control will slow the car. Your best pass will be with trac control off, no launch control and you can feel all that is happening in the seat of your pants. If you do not have that gift , use launch control.
I would like to see a 1.9 60' on street tires to be honest but I have like 0 seat time on the track in my c7
Probably at your track location but not down here in
South Florida (Bradenton). And on top of that at least the OP took the time to share his experience at the track. I would say that there are plenty of A6/A8's running high 11's. Are the manuals capable of going high 11's....of course. Low to mid 12's is what I am hearing for right now in stock form on an average.
I did about 6 runs in sacramento raceway starting from 32 psi's and lowering psi's on each run all the way to 15 psi's and i only got slower.. Only doing a burnout worked for me but my best 60ft was 2.04...My fuel tank was at 1/4. Tract prep plays a huge roll to achieve 1.9 , 1.8 i believe.
I had better luck taking my tires down to about 25 psi than leaving them stock. I have an A8 and went 11.52 on a 1.68 60' so I know if you practice enough you can get an M7 car to run way better than 12.5.
ran another night. pretty humid. 24 psi rear tires, ran (2) 12.5x quarter miles... seems to be the best im gonna get outa this car in stock form.
