Track Prep Document
Track Prep Document
The 2014 Corvette Stingray with the Z51 Performance Package has been designed and engineered to be a world-class sports car for the track. But before unleashing its acceleration, cornering and braking capability, there are several key procedures and steps that must be taken in order to properly experience its track prowess. For full details and information, see the vehicle Owner’s Manual. Please Note: The Corvette Stingray with the Z51 Performance Package is the recommended model for track use.
PART/DRIVING BEHAVIOR
TIME PERIOD
RECOMMENDED ACTION
Tires
First 200 miles (322 km)
Drive at moderate speeds and avoid hard cornering
Brake linings
Avoid making hard stops (recommended every time brake linings are replaced)
Full throttle starts and abrupt stops
First 500 miles (800 km)
Avoid full throttle starts and abrupt stops
Exceeding 4000 rpm
Avoid exceeding 4000 rpm
Cruise control or driving at one constant speed
Avoid cruise control or driving at one constant speed
Letting the engine labor or lugging the engine
Avoid letting the engine labor or lugging the engine. With a manual transmission, shift to the next lower gear (this rule applies at all times, not just during the break-in period)
Track or competitive driving
First 1,500 miles (2414 km)
Do not participate in track events, sport driving schools or similar activities
Engine oil
Check engine oil with every refueling and add if necessary (oil and fuel consumption may be higher than normal during the first 1,500 miles)
2. SEASON THE BRAKES
BRAKE BURNISH PROCEDURE (OWNER’S MANUAL: 9-9)
After the new vehicle break-in period, Corvette Stingray Z51 Performance Package brake pads must be burnished (following the steps below) before racing or competitive driving.
1. Medium Brake Application: Apply the brakes 25 times starting at 60 mph (100 km/h) to 30 mph (50 km/h) while decelerating at 0.4 g. Drive for at least 0.6 miles (1 km/h) between applying the brakes. This first step may be skipped if there are more than 200 miles (320 km/h) on the brake pads.
2. Hard Brake Application: Repeatedly apply the brakes from 60 mph
(100 km/h) to 15 mph (25 km/h) while decelerating at 0.8 g. Drive for at least 0.6 miles (1 km/h) between stops. Repeat until the brake pedal travel starts to increase. Depending on conditions, this should take no longer than 25 brake applications.
3. Cool Down: Drive at 60 mph
(100 km/h) for approximately 10 miles
(15 km) without using the brakes.
4. Medium Brake Application: Apply
the brakes 25 times from 60 mph (100 km/h) to 30 mph (50 km/h) while decelerating at 0.4 g. Drive for at least 0.6 miles (1 km) between applications.
Please Note: The brake burnish procedure is specific to the Z51 brake package and should not be run on any other models as damage may result. When this procedure is performed as instructed, it will not damage the brakes. The brake pads will smoke and produce an odor. The braking force and pedal travel may increase. After the procedure, the brake pads may appear white at the rotor contact. Perform this procedure only on dry pavement and in a safe manner and in compliance with all local and state ordinances/laws regarding motor vehicle operation.
Rotor cooling rings (provided at the time of vehicle delivery in a clear plastic bag) are recommended for track use (driving without the rotor cooling rings may result in brake pedal fade). Do not leave them installed after a track event, as this may cause corrosion with long-term use. Installation instructions are included with the rings and can be found in section 9-7 of the Owner’s Manual.
2014 CORVETTE STINGRAY
TRACK PREPARATION
1. ATTAIN THE RIGHT MILEAGE
NEW VEHICLE BREAK-IN (OWNER’S MANUAL: 9-17)
All Corvette Stingray models have a recommended break-in period during the first 1,500 miles (2414 km) that will prolong its performance and driving precision.
1
4. CHECK YOUR FLUID LEVELS
FLUIDS AND LUBRICANTS (OWNER’S MANUAL: 9-6, 11-12)
Be sure to follow all service procedures before driving Corvette Stingray (with the Z51 Performance Package) on the track or competitively. Any fluids or lubricants that are changed should be restored back to normal before returning to street driving.
The tires on Corvette Stingray (with the Z51 Performance Package) require inflation and pressure adjustment when driving at high speeds on a track (where legal).
Limit the vehicle load to the driver only, with no other cargo and inflate the tires to 26 psi (180 kPa); drive at a maximum speed of 174 mph (280 km/h)
Return the tires to the recommended cold tire inflation pressure when high-speed driving has ended
FLUID/LUBRICANT
TO DO
WHEN
Oil
(Mobil 1TM 15W50 Recommended for Track/Competitive Driving)
Check the oil level and keep it at or near the upper mark that shows the proper operating range on the engine oil dipstick
Often (before and after every track event or competitive driving session)
Brake Fluid
(Dot4 Recommended for Track/Competitive Driving)
Replace existing brake fluid with a qualified high-performance brake fluid from a sealed container (brake fluid with a dry boiling point >534°F [279° C] is qualified)
If high-performance brake fluid is in the vehicle and the age of the brake fluid is over a month old or unknown, replace the brake fluid before track events of competitive driving (if high-performance brake fluid is used, replace it with GM-approved brake fluid before driving on public roads)
Rear Axle Fluid
Because fluid temperatures may be higher, it is necessary to change the rear axle fluid
Every 24 hours of track events or competitive driving
Corvette Stingray (with the Z51 Performance Package) wheel alignment settings should be set as follows for track use (and returned to normal when high-speed driving has ended):
Front (per corner)
Caster: +7.0 degrees
Camber: -2.0 degrees
Toe: 0.05 degrees toe in
Thrust Angle: 0 degrees
Rear (per corner)
Caster: 0 degrees
Camber: -1.7 degrees
FRONT LICENSE BRACKET/AERO PANEL
The aero panel (if being used as a license plate holder) should be removed for track events and competitive driving to improve engine performance.
3. ADJUST THE FOUR CORNERS
TIRE PRESSURE AND WHEEL ALIGNMENT (OWNER’S MANUAL: 9-6)
2
TRACK PREPARATION
After driving your Corvette Stingray (with the Z51 Performance Package) on the track, it is important to return the vehicle
back to the original factory settings with the proper fluids before normal street driving.
Remove the brake rotor cooling rings
Return the tire pressure settings to factory
(see the Tire and Loading Information label located below the door latch with the door open)
Return the wheel alignment settings to factory
Reattach the front license plate bracket/aero panel (if removed)
Replace oil (use only engine oil licensed to the dexos1 specification of the proper SAE viscosity grade)
Replace brake fluid (DOT3 Hydraulic Brake Fluid)
Replace rear axle fluid (DEXRON® LS Gear Oil)
Rotate the Driver Mode Selector out of Track mode
AFTER THE TRACK
TRACK PREPARATION
3
5. TURN UP THE PRECISION
DRIVER MODE SELECTOR (OWNER’S MANUAL: 9-38)
Track mode should be selected for track use or competitive driving in Corvette Stingray (with the Z51 Performance Package). The outer ring of the Driver Mode Selector is located on the console behind the shift lever. It rotates to change the modes, which display in the instrument cluster.
PERFORMANCE TRACTION MANAGEMENT
(OWNER’S MANUAL 9-43)
Corvette Stingray models (with the Z51 Performance Package) that have Magnetic Selective Ride Control™ incorporate Performance Traction Management (PTM), which integrates the Traction Control, StabiliTrak® and Selective Ride control systems to provide consistent performance when cornering
in track situations.
To utilize PTM in Corvette Stingray (with the Z51 Performance Package):
The vehicle must be in Track mode
Then, quickly press the TCS/StabiliTrak button on the center console two times
To select a mode, turn the Selective Ride Control/Performance Traction Management MODE SELECT **** on the center console
PTM contains five modes. Mode 5 is race active with handling off. It is for use by experienced drivers who are familiar with the track, requires the most driving skill and should be used on dry conditions only. StabilTrak is off and engine power is available for maximum cornering speed.
For more details, see the Corvette Stingray Owner’s Manual.
Please Note: Participating in track events or other competitive driving without following the instructions provided may affect the vehicle warranty. See the warranty manual before using the vehicle for racing or other competitive driving.
TIME PERIOD
RECOMMENDED ACTION
Tires
Brake linings
Exceeding 4000 rpm
Engine oil
TRACK PREPARATION
1
FLUID/LUBRICANT
TO DO
WHEN
Oil
Brake Fluid
Rear Axle Fluid
Front (per corner)
Rear (per corner)
Caster: 0 degrees
2
TRACK PREPARATION
AFTER THE TRACK
TRACK PREPARATION
3
