ACS Composite SALE! | C7 Front Spoilers, Splitters, Rockers & MORE! @ JDP Motorsports
Former Vendor
JDP Motorsports is proud to offer, use and install ACS Composite products for your C7 Corvette!
ACS - Stingray Five1 Front Lip Spoiler - 2014-2015 C7/C7 Z06 Corvette - 45-4-031
ACS Five1 front spoiler for the 2014-2015 C7 and C7 Z06 Corvette is made from an OEM-validated RTM composite material, sits just over the current ride height without lowering the front, includes road guard protective coating for longevity, and OEM mounting points for simple assembly. Available in primer, satin black, and carbon flash finishes.
Add ACS front wheel deflectors to push airflow around the rotating wheels more efficiently, reducing lift and drag. The ACS deflectors for the C7 Corvette come with mounting hardware and install at the OEM wheel liner mounting points located inside the front fascia.
The C7 spoiler with no deflectors (part # 45-4-031) will fit Z06 models.
The C7 spoiler and deflectors (part # 45-4-033) will fit all Stingray
Product Features
ACS - Stingray Splitter - 2014-2015 C7/C7 Z06 Corvette - 45-4-003
ACS stingray splitter for the 2014-2015 C7 Corvette is made from an OEM-validated RTM composite material and features frontal aerodynamics, 3 undercarriage fins for optimal airflow, fuel optimizing non-restricting central opening, road guard protective coating for longevity, and OEM mounting points for simple assembly. Available in primer, satin black, and carbon flash finishes.
The C7 splitter with no deflectors (part # 45-4-003) will fit Z06 models.
The C7 splitter and deflectors (part # 45-4-005) will fit all Stingray
Product Features
ACS - Stingray Front Wheel Deflectors - 2014-2015 C7 Corvette - 45-4-007
ACS - Stingray Front Wheel Deflectors w/out Spats - 2014-2015 C7 Corvette - 45-4-027
ACS front wheel deflectors without spats for the 2014-2015 C7 Corvette were made for the track enthusiast with a RTM composite material and aerodynamic design that pushes airflow around the rotating wheels more efficiently, reducing lift and drag. The ACS deflectors for the C7 Corvette come with mounting hardware and install at the OEM wheel liner mounting points located inside the front fascia. Available in primer, satin black, and carbon flash finishes. Includes Free Shipping to the Lower 48!
These ACS deflectors part # 45-4-027 are identical to part # 45-4-007 but with the bottom spats removed and work with their C7 splitter part # 45-4-003.
$134.00 Shipped!
ACS - Stingray Five1 Front Wheel Deflectors - 2014-2015 C7 Corvette - 45-4-035
ACS front wheel deflectors for the 2014-2015 C7 Corvette were made for the track enthusiast with a RTM composite material and aerodynamic design that pushes airflow around the rotating wheels more efficiently, reducing lift and drag. The ACS deflectors for the C7 Corvette come with mounting hardware and install at the OEM wheel liner mounting points located inside the front fascia. Available in primer, satin black, and carbon flash finishes. Includes Free Shipping to the Lower 48!
These ACS deflectors work with their C7 splitter part # 45-4-003 or spoiler 45-4-031.
$184.00 Shipped!
ACS - Stingray Five1 Bumper Grill - 2014-2015 C7/C7 Z06 Corvette - 45-4-017
ACS Five1 bumper grill for the 2014-2015 C7 Corvette and C7 Z06 Corvette is a direct replacement for the stock grill and comes in a carbon flash finish. An added function for the Z51 owner is this grill's funneled brake cooling intake that will augment and enhance the functioning of the brake cooling duct.
$1070.00 Shipped!
ACS - Stingray Zero1 Rockers - 2014-2015 C7 Corvette - 45-4-001
ACS - Stingray Zero7 Rockers - 2014-2015 C7 Corvette - 45-4-015
Z06
ACS - C7 Z06 Rockers - 2015 C7 Z06 Corvette - 45-4-029
ACS - Zero1 Rockers - 2015 C7 Z06 Corvette - 45-4-055
ACS C7 rockers for the 2015 C7 and C7 Z06 Corvette are made with ACS' RTM composite process for a smooth finish on both sides and provide improved aerodynamic performance while the extended design of the rocker undercarriage section fully protects the OEM painted rocker section. Installation generally takes 30 minutes with the mechanical fastener kit supplied and avoiding the use of messy adhesives or double-sided tape. Available in primer, satin black, and carbon flash finishes.
Product Features
ACS - Stingray Rear Quarter Inlet Port - 2014-2015 C7/C7 Z06 Corvette - 45-4-011
ACS rear quarter inlet port for the 2014-2015 C7 Corvette and C7 Z06 Corvette is made from injection molded ABS-PC, a blend of polycarbonate and acrylonitrile butadiene styrene, and has an easy fitting using 3 supplied mechanical fasteners. This inlet port is also functional and designed to increase airflow to the rear mounted intercoolers on the Z06 and Z51 models. Available in a carbon flash black paint finish.
Designed for coupes, cannot be fitted to convertible Stingrays.
$424.00 Shipped!
ACS - Stingray Zero7 Carbon Hood - 2014-2015 C7/C7 Z06 Corvette - 45-8-009
ACS Zero7 extractor carbon hood for the 2014-2015 C7 Corvette and C7 Z06 Corvette is made from 100% aerospace grade carbon fiber and feature a true water fall extractor, 30 mm taller cowl, and black ABS octagonal mesh grill insert. This hood is stylish and includes quality OEM components that add style and performance to the Stingray design.
$2870.00 Shipped!
ACS - Stingray Aero Package - 2014-2015 C7 Corvette - 45-6-001
ACS aero package for the 2014-2015 C7 Corvette includes the ACS C7 or Five1 splitter, front wheel deflectors, and Zero1 or Zero7 side rockers. The ACS splitters improve airflow while not lowering the ride height. Front wheel deflectors help cool brakes under hard braking while extracting brake dust. The side rockers also do not lower the ride height with a complete undercarriage protection while matching the Stingray's lines. Available in primer, satin black, or carbon flash finish options.
Package Includes
ACS - Z06 Aero Package - 2015 C7 Z06 Corvette - 45-6-002
ACS aero package for the 2015 C7 Z06 Corvette includes the ACS C7 or Five1 splitter and ACS C7 Z06 side rockers. The ACS splitters improve airflow while not lowering the ride height. The side rockers also do not lower the ride height with a complete undercarriage protection while matching the Stingray's lines. Available in primer, satin black, or carbon flash finish options.
Package Includes
Please feel free to call, PM or email us anytime with questions. We appreciate your interest and look forward to working with you!
Best regards,
Tyler
888-308-6007
sales@jdpmotorsports.com
Product Features
- Manufactured in an OEM-validated RTM composite material
- Will not lower the front ride height of the car (Actually sits just over the current ride height, making it the most non compromising spoiler on the market)
- Use of OEM mounting points for simple assembly
- Road Guard protective coating sprayed on inner surfaces for longevity and show finish
- Includes Free Shipping to the Lower 48!
Product Features
- Complete undercarriage pan for protection and rigidity
- 3 undercarriage fins, which keep airflow laminar, while directing air to the brakes and rear of the car
- Fuel optimizing non-restricting mechanism achieved via central opening
$134.00 Shipped!
$184.00 Shipped!
$1070.00 Shipped!
Z06
Product Features
- Will enhance your car’s aerodynamic attributes at high speeds
- Will not lower the ride height of the vehicle
- Contoured profile for easy access
- Smooth finish to both sides that exudes class and facilitates easy cleaning
- Mounted to the original OEM rocker panel
- Protects OM painted rocker panel
- Installation kit
$424.00 Shipped!
$2870.00 Shipped!
Package Includes
- ACS-C7 splitter w/ deflectors 45-4-005/ACS-Five1 splitter w/ deflectors / winglets 45-4-035
- ACS-C7 front wheel deflectors 45-4-007
- ACS-C7 side rockers Zero1 45-4-001/ACS-C7 side rockers Zero7 45-4-015
- Enhances your car’s aerodynamics at high speeds
Package Includes
- ACS-C7 splitter 45-4-003/ACS-Five1 splitter 45-4-031
- ACS-C7 Z06 side rockers Zero1 45-4-029
Best regards,
Tyler
888-308-6007
Former Vendor
We have them on the shelf ready to ship! You can order ACS part # 45-4-001 on our website or give us a call toll free at 888.308.6007 to order over the phone.
Please feel free to call, email or PM me anytime with questions. I appreciate your interest in our products and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Former Vendor
Still at a great price! Give us a call and we'll get you dialed in . We appreciate your support in our product! Have a great day and weekend!
Kind Regards,
Brandon
801.545.4215
Kind Regards,
Brandon
801.545.4215
Former Vendor
Get the Looks, Form and Function you've been looking for! Upgrade with a factory look for only a fraction of the price!!!
Any questions, give us a call today!!!
Best Regards,
Robert @ JDP Sales
801*545*4215
Best Regards,
Robert @ JDP Sales
801*545*4215
Former Vendor
Let us add some style and make your car look mean!!
[SIZE="3"]ACS - Stingray Five1 Front Lip Spoiler - 2014-2015 C7/C7 Z06 Corvette - 45-4-031[/SIZE]
Product Features
[SIZE="3"]ACS - Stingray Splitter - 2014-2015 C7/C7 Z06 Corvette - 45-4-003[/SIZE]
Product Features
ACS - Stingray Front Wheel Deflectors - 2014-2015 C7 Corvette - 45-4-007[/SIZE]
[SIZE="3"]$134.00 Shipped![/SIZE]
[SIZE="3"]ACS - Stingray Five1 Front Wheel Deflectors - 2014-2015 C7 Corvette - 45-4-035[/SIZE]
[SIZE="3"]$184.00 Shipped! [/SIZE]
[SIZE="3"]ACS - Stingray Five1 Bumper Grill - 2014-2015 C7/C7 Z06 Corvette - 45-4-017[/SIZE]
[SIZE="3"]$1070.00 Shipped! [/SIZE][SIZE="3"]
ACS - Stingray Zero1 Rockers - 2014-2015 C7 Corvette - 45-4-001[/SIZE][SIZE="3"]
ACS - Stingray Zero7 Rockers - 2014-2015 C7 Corvette - 45-4-015[/SIZE]
[SIZE="3"]Z06
ACS - C7 Z06 Rockers - 2015 C7 Z06 Corvette - 45-4-029[/SIZE][SIZE="3"]
ACS - Zero1 Rockers - 2015 C7 Z06 Corvette - 45-4-055[/SIZE]
Product Features
ACS - Stingray Rear Quarter Inlet Port - 2014-2015 C7/C7 Z06 Corvette - 45-4-011[/SIZE]
[SIZE="3"]$424.00 Shipped![/SIZE]
[SIZE="3"]ACS - Stingray Zero7 Carbon Hood - 2014-2015 C7/C7 Z06 Corvette - 45-8-009[/SIZE]
[SIZE="3"]$2870.00 Shipped![/SIZE]
[SIZE="3"]ACS - Stingray Aero Package - 2014-2015 C7 Corvette - 45-6-001[/SIZE]
Package Includes
[SIZE="3"]ACS - Z06 Aero Package - 2015 C7 Z06 Corvette - 45-6-002[/SIZE]
Package Includes
Best regards,
antonio velarde
888-308-6007
sales@jdpmotorsports.com[/QUOTE]
Product Features
Product Features
[SIZE="3"]Z06
Product Features
- Installation kit
Package Includes
Package Includes
Best regards,
antonio velarde
888-308-6007
