My C7 (2015 base 'vert, M7) NPP doesn't seem to act as expected
This thread:
https://www.corvetteforum.com/forums...ck-result.html
and many others talk about the 1700 rpm hitch, when the NPP valves close, even in track mode, below 1700 rpm. Quoting from the post above
My car, built in late April of this year, doesn't seem to have this behavior. I've tested it in several ways. In all cases Engine Sound Management is set to Auto.
Cruising in 6th at speeds between 55 mph (about 1200 rpm) and 65 mph (about 1500 rpm). Mode switch set to Sport. Switch mode to track and the exhaust note gets significantly louder. Switch back to sport, and it gets noticeably quieter. Based on the linked post, I would not expect it to get louder when switching to track below 1700 rpm.
Cruising at about 65 in 5th (IIRC). In any case, engine rpm about 2000. Mode set to track. Gradually slow down until revs drop well below 1700. I don't notice any sudden change in tone or volume at any point.
Am I missing something in the way I'm doing the above tests? I've done them multiple times, and the behavior described is consistent. I can't get it to quiet down below 1700 rpm in track mode. Is it possible Chevy has heard the desires to have the valves stay open all the time in track mode, and made a running change in the software?
Something else that is different than I expected, but maybe everyone else already knows: I had assumed the valves were either open or closed. But it appears they operate at intermediate positions, too. Switching from Tour to Sport make the exhaust louder, and switching it to Track makes it louder still, while staying at the same speed and rpm. (I mostly notice this at slower speeds, where wind noise doesn't mask the exhaust note so much.) That seems to indicate that in Sport the valves were open only part way, while in track they were open further / fully.
Engine Sound Management (ESM) OFF/Track will NOT keep NPP valves open all the time for the 2014-2015 Stingray. Even with the ESM menu update to the 2015 ESM settings, and even in the OFF/Track setting, the NPP valves will still actuate by design in certain situations (low RPM, lugging, high gear highway, etc.).
M7 very pronounced below 1700RPM in 3rd gear and above. M7 owners call this the "1700RPM hitch".
Received 2,379 Likes
they operate off more than just RPM. throttle position, i am sure also things like manifold pressure, vehicle speed, driver demanded power, etc just to name a few things.
this is why Theta created/is working on a manual switch to over ride the seemingly unpredictable NPP logic.
I understand Theta's mod, which is designed to let you keep the valves open, even under 1700 rpm. Based on the post I linked, the under 1700 rpm seems like a hard limit. I'm saying that mine stay open under 1700 rpm even without the mod.
in track mode they rarely close. open at idle as well.
Try this experiment...
- Set ESM to Track so that the mode dial won't be a variable.
- Gradually accelerate.
- From 2-3 shift soon enough that the RPMs fall to maybe 1500.
- As you tip in to accelerate through 1700RPM, pay close attention to the sound.
- Try this for the 3-4, and 4-5 shifts where the shift point allows 1500RPM or less on the upshift and then tip in through 1700.
In this scenario, the change in volume at 1700 would be night and day when in ESM Off/Track if things are still programmed they way they had been.
For me, it was annoying since this RPM range of operation was 'normal' driving around town. Anything spirited it's a non-issue. But I have to say not nearly as annoying as the A8 and incessant AFM mode I'm dealing with now... But that's another matter.
I never explored all the other ESM modes (or left the ESM in Auto) when I had my M7. I, like many others, wanted ESM Off/Track to be be loud all the time and that was it. When that wasn't happening, it lead to the fuse pull and now the cool new MildToTheta switch.
If you can definitively confirm a programming change, I'd be happy to update the NPP thread. I have no access to a '15 M7 to test this on my own though.
So I tried doing this in 4th, 5th and 6th gears. I repeated this multiple times yesterday evening, and this morning and evening. (Too much traffic to run that fast in 7th.) But I got some interesting results.
In 5th and 6th, there is definitely no "step" between 1500 and 2000 rpm, either accelerating or decelerating gradually. In 4th, however, the step at 1700 rpm is very, very obvious.
What I'm not sure of, though, and will need to try to listen for, is whether in 5th and 6th the car is staying in quiet(er) mode even beyond 1700 rpm, or whether it's coming out of quiet(er) mode before 1500 rpm. I'll try some tests in 5th running lower than 1500 and above 2000 to see if I notice a step. I may have to wire in Theta's remote switch mod so I can manually switch the valves are between open and Track mode and see what happens with the sound. It'll be a while before I get around to that.
