Ring and pinion
Ring and pinion
OK - got a whine in the differentia when accelerating. Was told it more than likely is a ring and pinion problem in my 2002 by the dealer. I have a 3.42 and stall converter in my automatic. Checking prices on a 3.42 ring and pinion set from National Drivetrain and they are about $350.00. How's that sound. Also considering a new Getrag 3.42 differential for about $1,700. Don't know if it would be necessary to get the whole enchilada or not. Car has about 65,000 miles on it.
What say y'all...
Tom in Atlanta
What say y'all...
Tom in Atlanta
St. Jude Donor '13-'14-'15
I'm sure your ring and pinion are just fine----It is extremely rare to break these parts--If your's is broken or bad---It would not drive anywhere in gear
FIX-----Installing a ring and pinion is a complex technical job---best left to the experts--Espcially on a Corvette--- If your's whines--it was simply a BAD installation and the fix would be to take it to a shop that has done Corvette rear ends before---
The things that are extremely important on a rear end to make them smooth and NOT whine is the correct setting of the "BACKLASH" and the "PRE-LOAD"---This requires special tools and experience----Take it to a reputable rear end shop and all they have to do is buy a ring and pinion installation package that will include all the shims and adjustable pieces to re-calibrate it to factory specs----Kit is cheap---All the cost is labor-- for removal and re-installation----
