Sub Woofer question
Old 05-28-2015, 11:53 PM
Deandre Clay
1st Gear
Deandre Clay's Avatar
Default Sub Woofer question
So I added two Kicker 10's to my system set up. It sounds great accept that the noise cancellation system in the cabin is interfering with the subs making them hum horribly. A quick fix was to just disconnect the mic on the drivers side door. Has anyone else had this issue? And if so how did you bypass the system or make it work in harmony?
Quick Reply: Sub Woofer question
