Brembo & StopTech Brake kits
Old 06-15-2015, 08:03 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Brembo & StopTech Brake kits
Brembo Corvette C7, C7 Z51 Front 350x34 2-Piece Slotted
Front kit contains:
Two 6-piston monobloc calipers (Black, Red, Silver, or Yellow)
Street performance brake pads
Two 2-piece floating slotted rotors 14”/350mm diameter Type III
Retains factory Lines
Adapter brackets
These 6-piston monobloc calipers have more brake torque using a wide annulus
This kit is excellent for everyday driving and HPDE events
http://www.xplosiveperformance.com/B...ed_p_3606.html
Brembo Corvette C7, C7 Z51 Front 380x32 2-Piece Slotted Front
Front kit contains:
Two 2-piece floating slotted rotors 14”/380mm diameter
Adapter brackets
http://www.xplosiveperformance.com/B...nt_p_3607.html
Brembo Corvette C7, C7 Z51 4 Piston Rear 380x32 2-Piece Slotted
Rear kit contains:
Two 4-piston monobloc calipers (Black, Red, Silver, or Yellow)
Two 2-piece floating slotted rotors 14.9”/380mm diameter
Adapter brackets
These 4-piston monobloc calipers have more brake torque using a wide annulus
StopTech Kits for 2014-15 Chevrolet Corvette (C7) Z51
Front StopTech Big Brake Kits for the 2014-15 Chevrolet Corvette Z51 use a pair of wide annulus 380 X 32 mm directional StopTech 2-piece AeroRotors® and StopTech’s patented, forged, high performance, six-piston StopTech ST-60 calipers with patented stiffening bridge, as well as billet aluminum mounting brackets with stainless steel studs, DOT-compliant StopTech stainless steel braided Teflon brake lines, and StopTech's highly-praised Street Performance brake pads.
Rear StopTech Big Brake Kits for the 2014-15 Chevrolet Corvette Z51 use a pair of 355 X 32 mm directional StopTech 2-piece AeroRotors® and StopTech’s patented, forged, high performance, four-piston StopTech ST-41 calipers with patented stiffening bridge, as well as billet aluminum mounting brackets with stainless steel studs, DOT-compliant StopTech stainless steel braided Teflon brake lines, and StopTech's highly-praised Street Performance brake pads.
Call or PM
FREE SHIPPING LOWER US INSTALLATION AVAILABLE
Old 06-17-2015, 08:30 AM
Former Vendor
St. Jude Donor '13
Old 06-19-2015, 07:56 AM
Former Vendor
St. Jude Donor '13
Old 06-24-2015, 08:36 AM
Former Vendor
St. Jude Donor '13
Front kit contains:
Adapter brackets
Front kit contains:
Adapter brackets
Rear kit contains:
Adapter brackets
Call or PM
Old 06-30-2015, 09:16 AM
Former Vendor
St. Jude Donor '13
Old 07-02-2015, 07:13 AM
Former Vendor
St. Jude Donor '13
Old 07-07-2015, 08:15 AM
Former Vendor
St. Jude Donor '13
Old 07-09-2015, 09:29 AM
Former Vendor
St. Jude Donor '13
Old 07-14-2015, 07:55 AM
Former Vendor
St. Jude Donor '13
Old 07-14-2015, 04:31 PM
OldJedi
OldJedi's Avatar
OK, you have peaked my interest. I am tired of taking the wheels /tires off to wire mount the Z51 "Cooling Rings" and then take them off again when I get home from the track. Is there a direct substitute 2 piece rotor for the Z51 that fits and will work well with the stock Brembo calipers?
Old 07-15-2015, 07:54 AM
Former Vendor
St. Jude Donor '13
Yes there is a 2 piece setup that will work with the stock calipers.
http://www.xplosiveperformance.com/A...IR_p_3803.html
Old 07-22-2015, 09:25 AM
Former Vendor
St. Jude Donor '13
Old 07-24-2015, 08:31 AM
Former Vendor
St. Jude Donor '13
Old 07-28-2015, 07:52 AM
Former Vendor
St. Jude Donor '13
Old 07-31-2015, 07:23 AM
Former Vendor
St. Jude Donor '13
Old 08-04-2015, 07:56 AM
Former Vendor
St. Jude Donor '13
Old 08-06-2015, 08:45 AM
Former Vendor
St. Jude Donor '13
To Brembo & StopTech Brake kits
Old 08-10-2015, 09:20 AM
Former Vendor
St. Jude Donor '13
Old 08-12-2015, 08:15 AM
Former Vendor
St. Jude Donor '13
Old 08-14-2015, 07:46 AM
Former Vendor
St. Jude Donor '13
Quick Reply: Brembo & StopTech Brake kits
