2016 LT1 Revisions?
2016 LT1 Revisions?
There is an article in Hot Rod Magazine in which the lead development engineer for the new Camaro, Aaron Link, is quoted as saying that the LT1 in the 2016 Camaro would have a "legit air/oil separator", which is "cleverly packaged".
Does anyone know whether this is referring to the separator baffles in the current Stingray LT1, or something new to be in the Camaro, (and thus in the 2016 Stingray as well)?
St. Jude Donor '14-'15
Unless, as you noted, they're talking about the complex notches in the valve covers (which serve a debatable function), they could be referring to something similar to what the Z06 already has (an evaporative container - essentially a catch can).
I don't see any reason why this wouldn't make it to the 2016 Z51, but we don't have the service information on those as of yet.
St. Jude Donor '13-'14-'15
My guess this is a simple catch can---But GM rather than calling it that has changed the name to an oil/air separator-- Reason is ---my guess is not admit specifically that all LS1/LS2/LS3's needed one from the onset--as does the LT1
The term "oil/air separator" or "oil separator", has been used for a long time by many manufacturers, namely the Germans, for the CCV system oil/air separator part (which is typically just a plastic valve or like on the older M3's, a plastic catch can). It's definitely not an unusual or new part name for a catch can by the auto industry.
I would consider it completely normal for a manufacturer to use this term rather than the aftermarket slang term of "catch can".
But I would really LOVE to know if the 2016's have a revised CCV system.... That would put to bed a lot of theories on this forum as well as validate us getting an aftermarket solution (pre-16).
About 7-8 total
The 1lt is a GM fail in my book. My lt 4 has been great has doesn't
oil like the Lt1.
What's wrong with the 1lt package? Offers a great value, no?
Why would you call the LT1 a failure? Please elaborate
Mine had it from day one. A catch can is band aid. If needs catch can.
It is a joke. Like I said I'm a GM fan.
Had many Camaro's and Corvette's
with ls engines. None had issue like the many 1lt's do. Just look at the full catch cans and these are old driver's not beating the car.
1lt is a fail and I'll never buy another.
thanks
Retro fits kits include LS6 intake valley and PCV conversions and numerous catch cans
The LT1 IS cleaner than a LS engine--exception being the dry sumps have a tendancy to burble air bubbles and oil vapor back into the air intake vents---
I have catch cans on both of my G8's ( as well as my Z51 A8) ALL collect oil. G8's ( L-76/LS-2)seem to have just as much oil in the catch can reservoir per thousand miles as the LT1.
No way---everyone knows how dirty any LS 1-2 or 3 intake manifold is-- Even bone stock---A modded one whether hds/cam or boosted make the oil ingestion via the PCV system even worse !!---There are 100's or threads concerning this on how to clean up the manifold
Catch cans were never an issue or oil
Ton's of Lt1 using catch cans on the stock engines. Dry and wet sump both.
Can cans companies are selling more than ever for the lt1's.
1lt heads will be full of carbon and soot and may turn out to be not as good as the Ls3.
Look at the many oil problems on the 1lt the ls motors were never that had that problem.
ls engines didn't need one stock for sure your still wrong.
Never use a Catch Can on any of the LS1's, LS'3 or other in the past , did not see a issue. I hope this DI does not become a problem with build-up for me as other have seen. I may of had second thoughts if known. I also lease a Hyundai for a DD that has DI with now 31,000mi. that seem to run fine with no noticeable loss of power, if anything it seem to run stronger now with out adding any oil between 7500 mile changes. I do hope this C7 does the same as my DD does in time.
Check your tail pipes if a lot is coming out you know you have problems. Should be a hint of gray and no oil residue.
My lt 4 is burning a lot cleaner than the lt1 I owned.
I think I have a good one, no noticeable oil usage, pipes stay cleaner the then The LS3's I had. I did add a catch can anyway to be safer. I added the can after the reads and when I checked and cleaned TB I notice a very fine film of oil on the back side of the Blade, no noticeable oil in the PCV hose.
Sorry mine wasn't. ALL My ls motors ran clean and didn't use oil or a catch can.
As a tuner I have seen 1000's of LS engines and now about 50 LT engines---- My opinion and as most others the LS engine is dirty--period The LT with DI is much cleaner but as a cautionary device most install a catch can on a LT----
All the LT intakes I've examined have only an oil sheen in then where as in a LS engine if you left the intake on the garage floor T-Body side down they would have a puddle of oil emerge overnite---
My suggestion is if you hate GM so much and have nothing good to say about their engineering --Do us all a favor and go guy yourself a Mustang or Dodge !!
You are entitled to your opinion--but that is all it is your opinion--I am not wrong as you say but it is my educated opinion from MY experience---
HAHA! Where did I say I hated GM! Where? I like GM that's why I own 3 Corvettes. I just don't like the issue with the Lt1. Since it is well known and many many posts on it. A lot of blame of over filling but that's not the issue.
There is many more catch cans on Lt1's than Ls engines and about 0 on Ls motors.,. Only heavily modded
Ls motors even think about putting them on.
No the Lt1 is worse than any LS motor for oiling not convincing me otherwise. Too much proof with hundreds of threads.
None of my ls motors even had oil anywhere. I added headers and blower kits. Not behind the throttle blade either. I had see a few but not to the scale of the lt1.
Dude...any big motor with power can push oil. Regardless if it's a LS or a LT or a 351 Windsor or a hemi. It's just physics.
Dry sump cars had the issue of getting overfilled initially that caused all kinds of problems with oil in the intake. When motors get driven hard you get blow by and oil gets places. Your golden LT4 does it to...you just don't want to admit it..... It's the same damn motor practically dude..just with a blower on it.
And why don't you share how many engine failures you've had running your LS engines without a catch can----You seem to leave that part of your history out---Everyone knows who you are and your history--Always blaming someone else for blown engines when in reality--it's your stubborn attitude about common sense that keeps you breaking parts--
Haha! this keeps getting better! I never HAD a failure or any problem
with any GM Lsx engines. Breaking parts? Blow engines! My history? Your going senile. You have me mixed up with someone else.
