PTS FAB C7 Twin Turbo Kit - TAKING PREORDERS NOW!!
#41
Thanks for the detailed response.
Tell me how the efficiency of the turbo has anything to do with my question? It's about the amount of boost being pumped into a stock motor without some sort of detonation protection. Turbos are certainly more efficient but also create a lot more underhood heat. It's a trade-off.
It's like running race gas or meth... you can run more boost, but it burns cooler and safer to keep from detonating.
the benefits of a SC are cost, and instant power.
#42
Former Vendor
well a D1sc at 12 psi doesnt move the same amount of air two 6262's do at the same boost level.
compressor flow (lbs/min) is much more with twins than a single compressor. wFor example, lets say a 70mm single mid frame compressor (typical D1sc) will flow 72lbs/min at 15 psi thats roughly 720 hp worth of compressor flow ( 10lbs/min=100hp) and then you have these twin 5858's that move 55lbs/min a piece @ 15 psi thats 110lbs/min of compressor flow with two of them, so at 15 psi twin 5858's will have 1100hp worth of compressor flow.
less fuel is needed to create that kind of power at the same boost level the blower or single compressor system needs to make power.
#44
Former Vendor
oh yes, there will be many upgrade options, from 5858 CEA precicions up to 6466 CEA precisions, t3/t4/v band, gt3076r-gt3586rs, with t3/t4/ v band options.
yes we can work a budget option later that will include the kit minus hard parts (turbos, gates, bov's)
#45
I'm definitely interested in the budget option so I can piece it together a little at a time due to budget. Maybe some twin 6265s, or GT37Rs.
For the people complaining about price, you can get some cheap T4 based journal bearing turbo or a truck turbo and still make good power to hold you over till you can get a good one.
You could use a couple of these for a budget option if you wanted.
http://www.usedturbos.net/Catalog/Ne...ig-Kahuna.html
#46
Its idiotic to say system XYZ is more efficient than system ABC by simply comparing one very simple number / chart. Turbo systems are much more complex than looking at a compressor graph. Then to state its more efficient than something else is ridiculous. people seem to forget that you have a turbine on a turbo and how its performance plays into a turbo system is often missed. The fact that with a turbo, unlike a supercharger, by increasing the boost pressure you directly impact the Exhaust back pressure to manifold pressure ratio further reducing efficiency.
Now back to topic.
Performance Turbo, what the reason for going for a large intercooler in front of the rad? This is surely going to impact Engine cooling.
Now back to topic.
#47
Now back to topic.
Now back to topic.
Are you proposing reduced scavenging because the gasses have the turbine in the way now or something so less ability to suck the cylinders clean? I'm just tying to understand you last sentence.
#48
Remember that a supercharger probably takes 50+ hp to turn at these levels, so a comparable blower car is going to be behind this with similar fuel/timing/etc.
That's part of the reason you see some turbo setups last longer at "ragged edge" power levels on stock engines than blowers, the rotating assembly isn't seeing as much strain.
#49
Disagree. My friends that run a turbo shop do nothing but cast manifolds because they want reliable OEM quality setups. They won't do welded together kits because they want a kit that will run 100k miles no issues. There is some investment, but the issue is typically the time to get molds done, tweaked, and setup.
#50
LSRX (12-14-2015)
#51
Both are reliable and maintance free. The idea that turbos don't last or need more work is some silly thing that goes around. Better let all the industrial motors, diesels, and long haul trucking people know that turbos don't last. Cheap china junk that people hack up and throw together have given turbo systems a bad name, but a good well engineered kit, with good turbos (Garret, Borg) will last a very very long time.
#53
#54
#55
Because no one makes a good kit for a c6 vette that meets my goals. APS had a decent setup but they are hard to find.
If I could go back I may do the full custom, but I would only run a kit with cast manifolds. c6s just don't have room to build a nice kit. On cars that have room, no question asked, turbos all day. If this kit fits nicely and they do cast manifolds, I would 100% do that over a SC. The turbos do everything better assuming a quality kit.
#56
I don't understand how you can say it's crazy to state that a turbo system is more efficient than a SC system. The fact that a turbo system is more efficient is a widely known fact... How could you possibly argue against more power per boost pressure and not having to rely on engine power versus what is essentially recovering wasted energy?
#57
As you increase intake manifold pressure (imp) with a turbo setup you increase the drive pressure required to drive the compressor to deliver the added air / boost. This increases exhuast manifold pressure (emp) or back pressure. Now in a really well design system you might have a 1:1 ratio between emp and imp. However in most systems you run high ratio than that.
So as you increase the boost you are often increasing emp by more than the increase in boost. This makes it harder for the engne on the exhaust stroke to empty the cylinder.
As you wind the boost on even more it becomes even harder on the exhaust stroke. This higher back pressure also increases Exhaust gas temps which isn't great on a turbo motor either.
Anyway back to topic. Performance turbo, have you any renderings of the cast manifolds?
#58
The advantage of a tube setup is it's much quicker and easier to go from the drawing board (if it's been designed at all) to being fitted on the car. Plus it's much easier to change if needed.
Unreal, can you disclose who this company is? Do they not fancy doing a c6 kit?....
#59
Cast has the potential to be the best. They are strong, hold heat better and you can design the flow paths better than you can with tube. Look at the AMS gt-r or ARP audi kits for examples of what can be achieved.
#60
Also interested in the fueling requirements for this kit. As far as I know they should be similar to sc setups in that hp range. The kit does sound interesting though.
