Setting the performance timer start and end speeds on a 2015 Corvette
Under the performance sdash board display there is a display for setting for the performance timer start and end speeds on a 2015 corvette. I go into the display and it will not let me set the start and end speeds. Cannot find it in the manual.
Help
Help
If not....
I had an issue where mine wouldn't set or adjust even with the correct user input. Disconnected negative battery cable for 10 mins...problem solved!
I did click to the right arrow and the start stop speed settings are there but I can not set a speed with the arrows.
Yep, mine was doing this as well after it worked initially. Disconnected battery as mentioned above, and problem solved! I had intended to post my experience in Tech with pics, but never did...
