Noobie question on wideband
I am looking to buy wideband for my car. The car will only have procharger d1sc with 7 psi in the near future. maybe in a year or two add on heads cam and headers.
I want to buy dual wide band but not sure if I need to get something permanently installed in the car or just portable unit like AFX or LM2 dual
I like LM2 dual so far because of portability and it can be use as scanner and can plug into cigarette lighter for power source.
AFX is slightly cheaper when buy 2 but it require hardwire to power source and it only does AFR.
I have look into aeroforce interceptor gauge but since haven't find anyone make a pillar pot for gauge that isn't crazy $$$ and not sure about how the aeroforce wideband kit can hook to hp tuner. That kinda been a dead end for me.
Any input is appreciated.
I have looked at some headers, ARH has bung at the x pipe, pfade got their bung right after passenger upstream O2. So I guess it really can go either way.
Platinum Supporting Vendor
Go with the AFX, the old one. That is made by ECM and you can't beat their product. You don't really need to run it permanently mounted, it is good for tuning and then when your done you put the regular o2 sensor back in a put your WBO2 in a box. Don't get over complicated with it either, all the add on's are for the kids with Honda's so they have gauges going back and forth and different colors in their cars. Once you are driving it is very difficult to notice the gauge anyways and if it said it was lean by the time you realized it, the damage would be done.
