I need picture of wideband installed on the stock exhaust please
Like the title said... I finally jack the car up and was hanging out under the car to find a place for wideband sensors... No room
It almost look like I will need to remove exhaust for install the wideband bungs. Anyone got some pictures and pointers on how you do yours?
I can do it to the side right before the cats but that is toward bottom of the pipe. The instruction recommends to install on top...
Received 2,379 Likes
i just replace a narrowband and put it in open loop for tuning purposes and remove it when I am done. pointless to run it full time. it's going to show stoich all the time except when you're wide open throttle and even then it isn't going to vary much unless you modify and tune it.
dang man, I thought that's what you were asking....yes, of course if you want a permanent install you need to be in front of the cats and weld in a bung.
I also would like to see some pictures of where people actually installed the sensor at...
