Jet 180 degree thermostat
With a 207 opening temp, it won't be fully open until ~225, which gives you a pretty small window from the point the cooling system begins operating at full capacity and the engine getting too hot.
FWIW, I don't think the 194 temp in the ECM actually does anything important. All the fan temps, etc, are separate so if that number is actually doing something meaningful I can't find it.
Received 2,379 Likes
good to know.....is that from a 2014 or 2015 or it's now established they are the same temp rating?
