Alignment & bushings
Old 07-30-2015, 11:55 AM
Wormwood
Wormwood's Avatar
Default Alignment & bushings
I need help with some alignment issues...
First, I assume the rubber bushings within all the linkages allow some deviation from the intended angle or distance at which a particular linkage is holding the hub or spindle at, as the wheel travels up or down & as throttle or braking is applied.
So with this is mind, can the rear suspension experience bump steer as it travels up & down? Specifically, as the recommended settings call for 0°~ +0.1° of toe in for the rear, could the slop of the rubber bushings be enough to allow the rear suspension to change from a toe in state to a toe out state? Additionally could this happen with only one wheel independent travel? A momentary state of misalignment due to suspension travel going from a toe in to a toe out state?
I guess another way to ask is sorta like inadvertent bump steering for the rear suspension but limited to bushings & not the suspension geometry?
Wormwood
Quick Reply: Alignment & bushings
