AFE CAI 2015 A8 Z51 - Install Length of Time
For anyone who wondered how long it takes to install the AFE CAI on a Z51 C7. Here you go (time listed below each picture). No clue if I took too long to complete this install. First time doing it.
Note: I spent time reading through the entire instruction manual first and reviewing a couple of threads I found on the forum. Thanks to those who gave some tips to consider before starting. Also, gathered all tools up before opening the hood.
Hood open, can't turn back now.
6:35PM
Radiator air outlet channel removed.
6:41PM
MAF Sensor disconnected and factory intake tube removed.
6:44PM
Factory intake box removed.
6:47PM
AFE filter housing installed.
7:05PM
AFE air tube installed, MAF reconnected and vent hoses attached.
7:29PM
Radiator air outlet reinstalled.
7:37PM
6:35PM
6:41PM
6:44PM
6:47PM
7:05PM
7:29PM
7:37PM
I did go with the dry filter as I have over oiled filters in the past and just really don't ever want to deal with that again. Plus, I'm ok with buying a new one if need be...just lazy that way.
It does run different. Some good and some bad. Without a tune I noticed some strange throttle responses. Granted, this was just during a quick run to make sure everything was connected correctly. So haven't run it long enough for a learn cycle to complete yet either. Ran ok today however. As far as performance speaking, not really sure as my seat dyno has never been calibrated.
This is basically just prep for ARH mid-length headers when I find the right price on them. Plus I haven't decided if I am going to cermaic coat a set when I get them first or not.
...and I installed this to hold off the big mod itches while I decide if I want to go s/c or not...or when....
So in a nutshell, I did this mod basically because I could. No real goal in mind other then to satisfy my modification bug.
Thanks, wasn't sure how efficient that mod was vs. expected install time frame.
Former Vendor
6:35PM
6:41PM
6:44PM
6:47PM
7:05PM
7:29PM
7:37PM
6:35PM
6:41PM
6:44PM
6:47PM
7:05PM
7:29PM
7:37PM
Unfortunately that is the case in some instances, and because of it we recommend to give the car sometime to learn and it will perform as intended
I plan to do the AFE along with them when they come in, and a diablew custom tune.
Without. But the mids retain the rear two cats so I'm hoping I'll get the power gains and heat reduction of going catless but also cut down a little of the raspy noise and hopefully reduce some of the smell by keeping 2 of the cats.
I'm super excited to put them on lol
