C7 oil change disaster
Went to get my first oil change at the dealership today. I told the service advisor that I was no mechanic but that my car had the dry sump system in it and that I wanted to make sure that whoever serviced it would know. Went back to the dealership and found my car washed and shined up and ready to go. I signed the paperwork and drove it out of the bay. Once outside the check engine light came on and the engine shut off. The service advisor plugged the computer into it and it gave a code for lean fuel mixture. Upon further examination they found oil in places that it should not be. The guy that had changed my oil did not drain the sump system and overfilled the oil. The oil had no where to go but out where it could escape. There is oil all over the engine compartment and on the steering components etc. the air filter system is completed saturated with oil and oil is in the throttle body. What do I do? It is sitting in a bay at the dealership tonight as they await GM to provide a resolution........
Especially when I made mention of it. They found a air filter about 100 miles away and they were going after it when I left the dealership tonight. They said they were having 2 more overnighted. I suppose they are going to clean it all up and put it back together and then run it till the engine codes go away and there is no oil on the air filter. Is there any harm to the engine because of this and should they change the oil all over again?
I am nervous.......very nervous......I took pictures of everything and the service advisor admitted they were the ones who messed up. Incredible that the folks that built the car cannot service properly. They sent me home in a 2015 Silverado. I am supposed to get an update Saturday.
That is really inexcusable on the part of the dealership. I fully understand that they cannot reasonably assign a highly certified mechanic to do a simple oil change but that doesn’t absolve them of the duty to have the job done right. Don
At least demand the results of a comp/leak down test before accepting the car back.
Good luck
I will update everyone as soon as I hear from the dealership. That should be today/Saturday. Was it a full moon yesterday? My daughter had borrowed my Subaru and drove it to work. When she came out to get in it someone had ran into it and pulled the front bumper off. Hit and run.............man-o-man!
Tell us where you live so we can avoid getting too close to that much bad luck!
I hear ye! Okay....here is the latest.......I spoke with the assistant service manager today and she said they were still cleaning everything up. She said that they are putting new air filters in and then running the car. Once it has run for a specified period of time they will check the air filter to see how clean or dirty it is. They are on their 3rd air filter and the car is not where it should be. She said that I might have the car back late Monday. I am not holding my breath. When I go to pick it up I will carry a fine tooth comb to go over it........the saga continues....tune in to the same bat channel at the same bat time!
C7 Oil Change Disaster
At this point I'd be demanding a new engine.
Black and Red (05-20-2016)
We will see what happens on Monday. I may have to get Chevrolet involved if it is not resolved correctly. I am waiting on the dealership owner to call me. He owns several dealerships and brands.Thanks to everyone for your input and wise words!
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Pretty easy on a dry sump. I had my car full of oil all the way to the front of the throttle body due to a dealer topping off my system while it was sitting cold. By the time I got to Cincinnati, I had oil dripping out of my air filter and leaving one hell of a mess on my son's garage floor.
Elmer
[QUOTE=Jedi-Jurist;1590229537]At this point I'd be demanding a new engine.[/QUOTE
A little extreme, should be fine, Clean everything, Replace filters, change oil to proper levels, drive and change again. Biggest time part is all the clean up.
i remembered when i took mine in for the first time. Was little scared they would screw it up.
While they were changing my oil. they made sure each other knew it was a dry sump and it was different process. its all luck of the draw with dealerships.
PCV hoses to the air filter, through the intake hoses, fill the sound deadening baffle, up the intake hose, past the throttle body, into the intake, and every time an intake valve opens oil will go into the cylinder, would be my guess.
Elmer
Elmer
This whole situation OP is awful.
The fact that they are running your car and there is oil STILL contaminating the filter multiple times is unfathomable.
The oil from the severe overfill of the dry sump will have belched sufficient liquid oil into the intake tube that it HAS to have made its way into the intake manifold. And as said above, this can dump liquid oil on top of the intake valves too. NOT GOOD!
Had the dealership pulled the intake, PCV lines, and intake manifold, and then thoroughly cleaned them, then installed a new MAF (not a cleaned one after being doused in oil), the car should not have fouled a clean air filter. Period.
Also get all new spark plugs. The cats will hopefully clean themselves if fouled, but a CEL will let you know if not...
The fact they're running the car to "clean it out" is comical and sad at the same time.
The consequence of liquid oil in any significant amount making it into the combustion chamber has extremely negative consequences.
OP, I seriously would try to get someone at GM above these clowns to get some satisfaction. Sure your car comes with a 100k PT warranty (assuming 2014-2015), but a lot of bad stuff could have happened if your motor did shut down from liquid oil in the cylinders. Some may take time to show.
Once they fix your car properly, either request $1k in GM Store merchandise or a 10 year/100k $0 deductible bumper to bumper extended GM warranty.
Good luck, and keep up posted.
