Aftermarket thermostat failure / diagnosis / repair
ANY aftermarket thermostsat where the rubber is molded over the rim instead of crimped down into it;
-I have tested Lingenfelter AND the 'Summit' brand personally; Since they all came to market at same time and same visually there is plenty of reason to believe they are all same original manufacturer.
-you will notice your coolant does not come up to temp, or comes up very slowly
-your fans will cut on high
-your digital and or analog coolant temp will drop to zero
-you will get SES light and code (P0128, Coolant below regulating temperature)
The seal cracks/tears/gets blown off and down into the water neck.
My stock thermostat was available, so I pressed the center (easy) out of both and put the 160 bulb into the oem disc. You will need a pair of pliers or side cutters to ease the lip in to hold the new bulb snug. Once installed the water and bulb pressure will not allow it to come apart.
Back to working normally; 165 on the highway
If you do not change your thermostat setting in the tune you may still get the code because the car is still looking for 194* minimum operating.. Look in the tune for this:
I had no trouble with this changed to 175*
The ONLY direct drop in seems to be this exact Mishimoto, however from one of the threads above there is a customer who got an older Mishimoto stat designed like these others and of course it also failed (last in the following links). So ask them for a picture or something before buying.
https://www.corvetteforum.com/forums...post1593121984
Relevant threads:
https://www.corvetteforum.com/forums...t-install.html
https://www.corvetteforum.com/forums...ermostats.html
https://www.corvetteforum.com/forums...hermostat.html
https://www.corvetteforum.com/forums...the-ls3-2.html
https://www.corvetteforum.com/forums...good-idea.html
This does not mean these stats are a waste of time to purchase, still hundreds less than the next option, but PLEASE don't bother to install it as-is. Do the bulb swap (or find that Mishimoto above) and be done with it.
Relevant threads:
Flame Red (08-17-2017)
Nice job!
I found that when the cut rubber issue happened on my Lingenfelder 160 deg. T-stat, the the A/C also quit... which was really hostile as I was driving back to IA from FL in high 90 deg heat!. I immediately ordered a 170 deg T-stat from them, just before they took them off the market, as I didn't realize it was the gasket that had failed at the time.
When I replaced, I also noticed that the spring was pinching the rubber seal on the new 170, due to a burr on the spring end where it was snipped off when mfg.... I filed this off and rounded the spring head so it was impossible for it to pinch the rubber seal. Vehicle has been fine now for 2+ months of stop and go driving.
If I have the seal fail again, your mod is definitely the way to go. Would do it now, but want to keep original stock in case of warranty issues, as I understand GM doesn't like us to replace the stock T-stat with lower temp ones.(Possible excuse to void warranty on engine.) Need to order a second stock one to modify.
Mighty Mouse, when you drilled holes in the stock stat, that didn't lower your opening temp? what did or didn't it do. Is there any other way to mod the stock stat? instead of drilling holes or swapping out the center temp sensing pieces?
if you drill enough or big enough holes it will let water move around and slow the warm up process. I drilled too many and on colder days or on all highway the car would not reach minimum operating temp, but the standing problem is that drilling the holes doesn't change when the stat opens, and slowing the warm up process is not really all that useful if the end result is still the same.
but it was free to try!
I've had some success heating some of the coils on the spring, reducing the pressure applied to the Tstat & lowering the temps. ~10°-15° . Of course nothing will work properly without adjusting the calibration on the ECM, so changing the Tstat in relation to warranty is nothing compared to changing the temp. calibrations within the ECM.
By heating a single coil at a time, I'm removing that part of the springs ability to return to its original shape, however, since this reduces the overall length of the spring as well, it limits the amount adjustment I can do. I need to find some different springs altogether.
Wormwood
Additionally, modifying the spring is probably why my Jet Tstat hadn't failed. Since there's less pressure against that rubber & the housing, it's not pinching it as hard.
Wormwood
Wormwood
Wormwood
I decided to do your stock C7 Thermostat Mod. Used my 160 Deg Lingenfelder T-stat center with the stock holder, just as shown in the original post.
My main reason for doing this was to see how the Lingenfelder 170 deg T-stat with the rim mounted gasket was holding up. I am the person who filed down the spring before installation of the 170 a couple months ago, as I noticed the spring end was pinching the rim mounted gasket.
Unfortunately, when I pulled the Lingenfelder 170 T-stat, the rim gasket was also cut and twisted, so it was fortunate I removed it. I was suspicious that it had failed, as I did have one instance where the fans were running full blast, even though the engine temp was around 170.
SO... IT APPEARS THAT THERE IS NO WAY TO MAKE THE LIGENFELDER T-STAT's WORK. They definitely made the correct decision to quit selling them.
Before I merge/modded the original stock T-stat with the 160 deg center, I purchased a new stock one, which can only be purchased with the plastic elbow and spring cage that holds it. Total cost with shipping for part #12658723 was just over $50. Note this is for a 2015. The part # for a 14 is different and the price is less.
Shortly after my LF 170 deg install back in mid-June, I contacted Lingenfelder about what I thought I had found as the reason for the cut gasket. It was also just after they discontinued selling their low temp T-stats for the C7.
They offered to refund my money or replace with a revised one, when they came available. It has now been 10 weeks with no further information. I e-mailed them last night, so hopefully I'll know more next week.
For those who have a defective LF T-stat, doing this mod, using a newly purchased original T-stat would have an overall cost of around $80. That is close to what I paid for my 170 deg. T-stat for my Twin Turbo Flex, and much cheaper than the over $200. option that includes an aluminum housing.
Supporting Vendor
We should have plenty on the shelves ready to ship. Please feel free to email sales@latemodelracecraft.com or just give us a call at the shop to place your order today.
Steven Fereday
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
Steven Fereday
I'm curious; mine is having similar problems with the LF T-stat installed.
How does a mechanical failure (i.e. a seal coming apart), cause the CTS to send the ECU into fail-safe mode?
Since I did this mod using the 160 deg LF bulb and the original T-stat housing ring, and am again getting the code but no check engine light, I think the C7 ECM doesn't like temps that are under 170 after a certain period of time, like 10 minutes of driving or so. At least I have a 15' Z51 A8. 15' uses a different T-stat than 14', which is slightly lower temp from GM, so 15' runs slightly cooler anyway.
I am going to pick it up from the dealer today and put the stock T-stat back in.
The symptoms to me sound electrical in nature.
Why would the analog & digital gauge read zero?
Why would the analog read zero and the digital read 164?
Why would they suddenly read the correct reading while driving.
Mine did not throw any CEL codes, but did disable the AC, and put the fans in high mode.
Very odd.
Very odd.
i had no trouble with this changed to 175
Very odd.
Very odd.
it is surely all caused by slow or not-reaching desired operating temp. why gm chose to trigger the things they did to get the drivers / dealers attention is something im sure we will never understand.
if you do not change your thermostat setting in the tune you may still get the code because the car is still looking for 194* minimum operating.. look in the tune for this.
My 170 deg. Lingenfelter T-stat never caused any issues until the rubber seal failed, and even then, when it went into limp mode, the next time out it didn't do it. At that point, I had received my second stock T-stat, so I decided to see if the 170 LF T-stat had failed and do the Mighty Mouse mod using the 160 deg. bulb if it had.
I did this mod without wanting to tune my ECM at this time. If it continues with the 170, I will go back to my stock T-stat.
im sure gm reserves the right to void the warranty for anything aftermarket, and is more an excuse and deflect blame than some bona fide warning of impending danger
Can anyone explain why either the thermostat gasket failing or the tune not being adjusted to reflect a lower temp T-stat would result in the temp gauges reading '0'?
Still not getting this...
Received 2,379 Likes
car computer logic today is weird. better to just do than try and understand some of it unless it REALLY REALLY matters to you.
My DashHawk is reading the temps correctly while the gauge on the dash reads 0. My guess as to why the gauge on the dash is reading 0 is that GM programmed it to do that to alert the driver that there is something WRONG! You will note that the oil temp gauge on dash is still working when water temp gauge is not.
