LG Motorsports G2 Coilover Kit for C7 Corvette-FREE SHIPPING!
Old 08-14-2015, 06:28 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Default LG Motorsports G2 Coilover Kit for C7 Corvette-FREE SHIPPING!
PLEASE PM FOR SPECIAL PRICE
0% Financing Available for All Parts Purchases Through TPS for 1 year!
**Ask for more details.
Bilstein is at the top of the heap in shock technology world wide. Their nitrogen filled separate chamber technology has been the standard of the shock industry for years. It was only a short time ago that the technology was allowed to be duplicated.
We have used these Aluminum Body Bilstein Shocks as the core of our Coil Over package for years now. The valving was dialed in by Lou and Bilstein shock engineers on the track and on the street.
We Built valving for street cars and for the race car. Of course most of you know the success that we had on track with the Bilstein/LG Coil Over package, winning races against some tough teams and drivers.
Our Coil over package that we have been building for over 8 years for the Corvette uses the best and highest quality Hypercoil springs. I know that the Corvette Market would accept nothing less than the best, so Hypercoil was our choice.
Combine the Bilstein Aluminum Nitrogen Filled Coil Over shock with the Hypercoil Springs and we have a premium coil over package that is race tested, race winning and street proven.
Our Pricing is less than 1/2 of a similar Moton or Penske package with equal performance as shown on the Race track. And our pricing is only slightly higher than the heavier steel coil overs. And for the street, we apologize for giving you more than you need. But at LG Motorsports we consider that "Value".
Here are some questions that you should ask when getting any Coil over package:
1. What material is the shock made of? Is is heavy steel or aluminum?
2. Is it Gas filled with a separate gas chamber? Because if it is not separate, the shock oil will trap air bubbles and reduce and change the effectiveness of the shock with each stroke of the shock.
3. What Brand of spring is being used? Hypercoil, Eibach, or some off brand with no name. The no name springs will sag and take a set, where the Hypercoil springs do not. They are "Pre Stressed" and blanchard ground top quality wire to insure that their installed height does not change.
4. Does the shock length cause it to bottom out when it is loaded in a corner? We took the time to have Bilstein build our LG Shock to our custom length so there is no chance of the shock bottoming under loading. If a shock bottoms, the effective spring rate goes to infinity and the tire is now the only "shock" absorber in the suspension. Obviously this is not a good thing.
5. Adjustability? Adjustable shocks work well for Drag racing because you need a 90/10 shock for the front and a 50/50 for the rear to promote weight transfer. But for all other applications, you need a tuned and balanced shock spring package that work in harmony. The ***** on the shock work well when you change your spring rate but if your springs are already correct for the shock then you will take the shock out of the range of the spring if you are just turning *****.
In other words: The rebound of the shock IS determined by the spring rate. The rebound rate is what is acting against the spring pressure. If you change the spring rate, you MUST change the rebound rate of the shock because a heavier spring rate will push the shock open quicker or similarly a lighter spring will not be able to over come the rebound in the shock and tend to "hang" the wheel up and reduce the tire contact time. So they both work together, and if you just change the shock rate with a **** without changing the springs to match the shock change, then you have just taken your shock/spring package out of "harmony" and it will not work as designed.
Our Shock/Spring package was developed by LG Motorsports in conjunction with the highly skilled engineers from Bilstein. We at LG Motorsports have nurtured our racing contacts to be able to carry that technology into the street products that we build.
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Old 08-28-2015, 12:53 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Bump for the best coil overs on the market for the price!
-PM or contact me for Special Pricing!
-0% Financing Available for up to 1 Year
-Accept ALL Car Care One Card!
-Summit Racing Speed Card, Discount Tire, Pep Boys & ANY Car Care One Card Accepted!
-FREE SHIPPING IN THE USA!
Old 08-28-2015, 01:02 PM
C7&7
C7&7's Avatar
Mike any smarts to allow these to work on a Z51 mag ride car yet? To avoid disabling it.
Old 08-28-2015, 02:22 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
You can use these without a problem... you will just just lose all the features of the Z51 and mag ride
Old 08-28-2015, 02:25 PM
C7&7
C7&7's Avatar
Right...but will there ever be a way to keep all that? Is there another product out there that allows it?
Old 08-28-2015, 03:03 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
No because the expense would be outrageous to design a system to work with the Mag ride
Old 09-05-2015, 12:14 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Happy Labor Day Weekend!
Give us a call and we'll help reward yourself with a new set of LG Coilovers! Whether your looking for a set for the street or the ultimate setup in the G2 (which is AMAZINGLY inexpensive for what you get) we can take care of you!
0% Financing available for up to 1 Year through Synchrony Bank/ GE Bank Car Care One Program.
-We accept ALL Car Car One Cards.
Old 09-21-2015, 02:06 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Old 10-02-2015, 03:36 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Are you looking to improve the handling of your Vette? OR lower your Vette without compromising the ride? Take a look at the LG Coilovers... there is no better coilovers on the market for price!
Old 10-15-2015, 10:47 AM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Bump for the best coilovers possible for your C5, C6 or C7! Who else wants a set? Whether your just cruising around the streets OR doing some serious driving these coilovers are a MUST!
0% Financing for up to 1 year! All Car Care One Cards accepted!
Old 10-27-2015, 11:08 AM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
All orders shipped!
Whether your just cruising around the streets OR doing some serious driving LG coilovers are a MUST! These are the best coilovers possible for your C5, C6 or C7! Who else wants a set?
Old 11-10-2015, 01:32 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
No better Coilovers for under $4000! These units (G2 Coilovers) are some of the best on the market and what LG uses on their World Challenge Race cars. Shocks are made Bilstein and each shock is spec'd and custom made to your needs! The G2's work great for street and track.
If your looking for a great street setup... LG offers the GT2 Adjustable Coilovers for your C5 and C6.
0% financing for up to 1 year available on all LG Motorsports products purchased through TPS! Free shipping to any address in the continental USA
Drag Racing versions available also
LG G2 Coilover
Old 11-10-2015, 07:10 PM
mustclime
mustclime's Avatar
What are the spring rates of these? What tires were they tuned for?
Old 11-10-2015, 08:44 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
These coilovers are custom tuned to your needs and specs. Spring rates will vary based on what your looking to do and your needs. What type of driving do you do?
Old 11-10-2015, 10:00 PM
mustclime
mustclime's Avatar
DD + autoX + track days....tires are stock + a set of RE-11's for the fun days.
Old 11-11-2015, 03:32 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
PM sent...
Old 11-20-2015, 11:30 AM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
BLACK FRIDAY COILOVER DEAL!
PM or call for special pricing@
To LG Motorsports G2 Coilover Kit for C7 Corvette-FREE SHIPPING!
Old 11-28-2015, 10:49 AM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Bump for our best sale of the year! Everything is on sale!
Click here to place your orders
http://www.tpsmotorsports.com/black-...-corvette.html
0% Financing Available for up to 1 Year on ALL PURCHASES!
Old 12-12-2015, 02:31 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Christmas Special!! Lowest Price of the year!
It's the gift that keeps on giving ALL YEAR ROUND!
Old 01-14-2016, 10:34 AM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Didn't get what you wanted to get for Christmas? Get a set of LG coilovers to start the year off! No better way to transform the handling of your Corvette!
LG G2 Coilover
LG GT2 Coilover
Quick Reply: LG Motorsports G2 Coilover Kit for C7 Corvette-FREE SHIPPING!
