HOW TO: Install Alky Control Meth Injection system in a C7
#61
So I have waited months to take on this task. I don't even have the blower installed yet but this was a more tedious install so I decided to take it on first. So I have spent an hour spilling washer fluid everywhere and removing a ton of bolts. Note if you have a kit (I have a APR CF kit) You will need to remove a few screws from the rocker to get the inner fender loose enough to work. So here are my first round of questions.
How do you get all the washer fluid out without removing the actual tank?
We remove the pump and block it off. What do we do with the flow? (Leave it in so we don't get a dummy light?) I assume the car will see "fluid" in the tank and be fine?
I also installed my led light here which was very easy it slides right in.
I mounted by control box right behind the carpet at the very end of the console. Its hidden but still accessible if needed.
#62
Nice. I ended up just washing the floor in my shop for the most part lol. I removed the pump and 90% went into a oil container. The remaining on the floor so I simply washed where I was working. Once I drilled the hole in the bottom the remaining dripped out but I am sure there is still a tiny bit left. Hopefully the Meth will just absorb it HAHAHA
#63
I had the shop do mine but the interior panel behind the drivers seat squeaks like mad at times.
They have had it apart and back together twice now, still makes a ton of noise.
If I wedge something between the window and the plastic it stops, for a while, then I have to move it again.
Anyone have problems with that panel making noise?
#65
I have more that I did not load online. Let me know exactly what you need to see??
https://www.corvetteforum.com/forums...dyno-tune.html
#68
You will need one.. Running A&A kit and it was mandatory. Not for easy driving but if you race it is.
#69
Is the silver metal piece of number 22 a ground or just a mounting bracket .... my dash shuts on and off when I floor it. My light turns red and green still though trying to figure out where my short is coming from
#70
Thats the only thing I can think off.. the meth kit doesnt touch anything else that could create that.
#71
I had headers / Ecs supercharger/ alky done at once I will double check all the grounds that I noticed that part 22 was loose that's why I asked if that was a ground I will have to re go over every wiring step of the alky control and supercharger any tips or things u guys think effect my dash shutting on and off would be appreciated !
#72
#75
That's the power relay but if that had any issue the meth kit would shut off. And your not having a problem with the power. It's connected at the fuse box in the back and has a fuse tap to energize the gray wire
#76
I just went over everything the the power relay was hooked up on the 60a screw that comes out the battery instead like the one in this thread is hooked up on the bigger power terminal so I switched that made sure all the grounds where in place and tight. Tested the meth it works good I don't think the meth is messing with my dash it's definitely something else
#77
those get loose your dash will wig out
KostaT26 (11-22-2016)
#79
why are you canceling the windsheild water pump? Also, can i use my OEM GM map sensor signal (Z06) instead of vacuum/boost hose to mechanical map semsor provided with the kit?
Thanks Fyreant!!! Extremely helpfull!!
