Magnuson Heartbeat Supercharger
All,
So I have had my 2015 Z51 Stingray since March. She is a dream. This week I plan to add a ZO6 front grille and a MGW shifter kit.
So here is the question. Magnuson just released their Heartbeat Supercharger for the C7.
I would be interested in everyone's thoughts on this product.
CB
CB
It will be the same as every top mount blower before it..
It will run hotter and make less power than the centri setups but give you instant torque off idle. That's great when your car weighs 4K+ lbs, but in these corvettes it is useless power.
My advice, see if you can find someone locally that has a centri powered car and a PD powered car and go for a ride. From C5 to C7, it doesn't matter the year, buy what you like the feeling of.
I have been going back and forth between the centrifugal v. roots blower for a long time, but I keep coming back to the same issues.
Why don't OEM manufacturers install centrifugal blowers? The ZO6 has a roots blower, in fact it might be made my Magnuson. In street type driving, isn't it more beneficial to have the power down low where it is more useable. I won't be driving my Vette on the drag strip.
No flames please.
CB
No flames please.
CB
Supporting Vendor
We were the first to do this setup and have pushed it as hard as we can up to this point. Until someone comes out w/ an overdriven lower for a non dry sump we can't spin it any higher. Here is the latest dyno video in 105 air. Any questions on this setup we can help as we have lots of experience w/ this and have done a ton of testing here in satan's armpit haha.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
St. Jude Donor '14-'15
No flames please.
CB
No flames please.
CB
As an example, small turbos may spool by 1800rpm and run strong through 3500, and then drop off a cliff. On the other end, a turbo that doesn't spool until 3500 and then takes off like a rocket (think Supras here) is a completely different experience.
Most consumers are going to prefer the 'feel' (illusion) of more power that they get from small turbo or roots applications on platforms like the Ford EcoBoost.
On top of this, roots packages are usually easier to design from the ground-up when creating a supercharged model, and generally look cleaner as they require far less room for charge tubing, etc. They're also quieter, as previously mentioned, and ASE dealership technicians are familiar with the overall repair procedures.
I'm not aware of any modern production vehicle that has used a centrifugal supercharger from the factory.
This about sums it up. Also don't forget that eaton is a major OEM supplier so it is very cost effective to use their rotor design..
Manufacturers use roots superchargers or single/twin turbocharger(s) to obtain larger numbers at a lower RPM.
OMG ITS OUT NOW? I'm ordering after payday. You notice that the king of superchargers is a roots style blower. That's generally whats on all big racecars. I'm no expert though.
You'll find that all of the 'big racecars' are generally using direct-feed turbochargers or centrifugal superchargers along with nitro methane and parachutes.
Holden (HSV GTS), 414ci, big-ish cam, ~600rwhp.
Not everyone wants to spend their life only driving in the 4-6k range.
Just saying ... Technology moves on and some of the old truths are no longer compatible with reality.
The 4000-6000 band was an example of the worst possible conditions we could hit both types of blowers with. You know centris hate that range just as much as roots do.
Problem with the statement is that it's too generalized to be reasonably factual:
... has to be followed up with 'in some situations'.
Side note: I love the HSV GTS. After having 3 GTOs (and paying to convert one to a Holden exterior), I can't shake my love affair.
It is now incorrect to state that a centrifugal runs cooler than a Magnuson Heartbeat.
Same with the statement above "It will run hotter and make less power than the centri setups ..."
Stating that "A Roots will run hotter" is like saying "A centri will require more maintenance" ... it depends on the design, application & driving style.
I have owned most forms of FI ... they all have their application.
Side note: Owned Holdens most of my life - last one was a blown Senator. Nice, but not as nice as the CTS-V or the C63 ... but I still would like an HSV in the garage to play with
Well... except for the 'Twerbo' where the SC spun up until the turbo spooled and then de-clutched. That was an Eaton/VW venture that went horribly wrong.
So, all but that example have their application.
Performance Defined, Can you post you figures for this? its great to see how far the PD blowers have come along.
On the drive issue, is there no way of running a secondary drive belt to the SC with a higher setup (thinking like the old rear drive TVS2300s on C6s)
Lots of crap in this thread..
First off, there is NO PD blower that is efficient or produces lower IAT's than a proper centri setup. By the nature of the beast it just is not possible.
PD blowers are mounted on top of the engine, absorb massive amounts of engine heat, recirculate air, and have tiny and inefficient heat exchangers.
Centri blowers are mounted off the side of the engine with minimal block contact so they absorb less heat, bypass air to atmosphere instead of recirculating and they generally use large front mount intercoolers that actually work and cool the air charge.
I have owned both types of blowers on several different platforms. Street, road race, and drag race. I currently have a Whipple unit (the best screw blower on the market without a doubt) on my 2015 6.2 Sierra making 12psi and the IAT levels are not even close to the IAT's I see coming out of my YSI making north of 20psi pre methanol injection. Post meth its not even in the same ballpark.
If a PD blower was seeing super low IAT's it was due to a faulty sensor or very bad sensor placement, one of the two.
Until someone from a reputable shop (LMR, Vengeance, couple other forum sponsors that acutally build great cars) posts side by side logs that show anything even remotely close to what is being claimed here, I am not buying it based on my personal experience.
Also, the next person that compares a roots/screw blower to the blower on a top fuel dragster needs to just be slapped. You are talking about a car that makes 10,000hp, runs on alcohol, and is running for less than a min in most cases. Not even in the realm of being comparable.
But lets talk about "street" cars....
How many PD blower cars do you see being competitive in the half mile and mile races? None
How many PD blower cars do you see being competitive in the 6-7-8-9 second drag radial races? None
Both dominated by Centri blower, Turbo, and Nitrous...
You know where PD blowers shine? Heavy cars and trucks that need that low end grunt to get going. The whipple on my truck is a blast, but that is where it belongs. Its never going to be "fast", it just needed to not be boring..
Z06NJ (11-09-2017)
