Rookie Q - Magnetic Drain Plugs?
Just pickup up my 2015 A8 Stingray
Does it come with magnetic drain plugs on oil pan and transmission?
If not, where can I get them?
Tks.
Tks.
Not on the oil pan. Not sure about the transmission.
For the oil pan: http://www.powerslutracing.com/c-107...read-size.html
The wet sump engine use part # PSR-0104. I'm not sure if the dry sump uses the same one, but I suspect so.
Thanks mucho perhaps the parts counter knows the sizes.
W
Mid America had magnetic plugs at one time for the older corvettes, I know because I replaced all of them in my 02 Z06 years ago.
I'm sure they will include the new corvette soon if they haven't done it yet.
Thanks for your replies. Looks like several sources have oil pan drain plugs but I cannot find a plug for the AT.
One source mentioned has a wide variety of plugs with many different sizes and thread patterns. So there is one out there but I don't know the thread pattern of the AT drain plug in order to select the correct one.
Any ideas as to the AT drain plug thread pattern?
Tks,
Will
Tks,
Will
Tks,
Will
Tks,
Will
Note, the differential does have a magnetic drain and fill plug...Factory plugs have a nylon gasket..
I purchased 2 magnetic drain plugs for my Z51 from one of the vendors listed above. The size is pretty much universal as it is the same size as my G8(s) and my 2010 Flex. For added protection you can add a magnet to your oil filter. But... aluminum is not magnetic so any aluminum residue must be caught in your filter.
Dimple magnetic drain plugs
I have had good experiences with this company for magnetic drain plugs:
http://drainplugmagnets.com/magneticdrainplugshome.php
