Stumbling 2015 Z51 C7-HELP!!!!!
Check spark plug wires-are they on all of the way.
Is one burnt from a header.
Did one get damaged when removed.
All very common problems with new headers. Rule out the simple stuff first.
SharkAttack15 (10-07-2015)
My car has stuttered/stumbled/misses(whatever name you want to call it) at full throttle hard pull since it was new.(in any gear)
I tried everything I could think of, (plugs, wires, looked for vac leaks etc.) at full throttle on a hard pull it stutters like someone pulled off a plug wire.
Took it to chevy dealer the computer says nothing so they know nothing.
I'm thinking it has something to do with DOD.
I won't take it back because they will just drive it again and tell me they didn't feel anything and everything checks out.
The only way I don't notice it as much, is if I step into it slowly.
so i got my car tuned i have throttle body cnc, TSP headers w/ xpipe no cats, and drop in filter.. After a few days my car started stumbling under full throttle and it shakes ?? i was wondering if anyone had such a issue of some sort.. I did take it in to Chevrolet before this due to the rear end service light came on said the computer was malfunitioning and they cleaned it.. AS OF RIGHT NOW NO CODES!!! DRIVES NORMAL BUT WHEN I STEP ON IT STUMBLES
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
See the bold, underlined red text in your OP quote?
It ain't right! Get it redone and this time have it done correctly. Your tuner missed something.
Dealer won't touch a car with an aftermarket tune. What they will do is make a note of the tune, enter that information into their system and void your drive-train warranty.
Elmer
Elmer
Elmer
fixed it.. cylinder 2 misfire, changed spark plug and wire.. back to NORMAL!!! THANK GOD! no code poped up.
John Micheal Henry (10-09-2015)
St. Jude Donor '13-'14-'15
Tuners are always he 1st ones to be blamed for any issues once they've tuned your car from that day on forward----When in reality it is almost never the tune that is causing their issue----Again here it was poor workmanship on a simple plug and wire install and the tuner was blamed-----We have to have pretty broad shoulders to be blamed for other people's mistakes--- Glad you got it sorted----!!!!!!!!!!!!
