C7 Z51 18" rims for road course track
hi,
I am looking to get a set of 18" rims for road course track driving. I am thinking 10" front and 11" rear. I will then run Nitto NT01s 275 front, 305 rear.
Any recommendations? what offsets and brand? Any issues with rubbing and clearance?
I have gone with OZ racing rims in the past with very good quality and reasonable price for the 911 and Cayman cars I've tracked in the past.
I have done searches but nothing definitive. Only C6 square set up on a C7.
TIA
TIA
Actually 18" C5 Z06 rear as square setup all around as some tried on below thread
https://www.corvetteforum.com/forums...or-my-z51.html
How are you doing with stock brakes? Mine didn't do too well on the track so I went with AP BBK. I want 18" wheels but I doubt that they would work with the 6 piston AP calibers
C7 setups:
Front, C5 Z06 rear wheel, 18 x 10.5, 58mm
Rear, Oz Alleggerita, 18 x 11, 75mm, listed as a C6 rear wheel
But there's nothing wrong with an 18/19 setup or even a 19/19 setup.
Oz Superleggera III
Front, 18 x 9.5, 59mm, use 3mm spacer, listed as a C5 front wheel
Front, 19 x 9.5, 59mm, use 3mm spacer, listed as a C5 front wheel
Front, 18 x 10.5, 59mm, listed as a C5 rear wheel
Front, 19 x 10.5, 59mm, listed as a C5 rear wheel
Rear, 19 x 11, 75mm, listed as a C6 rear wheel
Oz Superleggera III
B Stead, you seem pretty knowledgeable on the topic. Can you advise me on whether an 18 x 9.5, 56mm will fit on the front of a z51 with 275/35/18" Nitto NT01 tires?
I plan to use 18 x 10.5, 56mm on the rear with MT ET Street Radial 315/30-18.
Thanks for any help.
The wheel and tire at the rear should stick out and so the car shouldn't be lowered.
The front tires are not tall but they are taller than the rear tires
DoubleDown (11-20-2015)
I have been using the TSW Interlagos wheels on mine with R888's, 275 front and 295 rear. Great set up and they fit perfectly. They also clear the Wilwoods in the front and rear.
