Best lube for sway bar bushings?
Installing a set of Phaft sway bars this Thanksgiving and wonder what you guys recommend for lubricating sway bar bushings soas to eliminate possible noise.
Received 1,762 Likes
I'm Batman..
Pro Mechanic
Best lube hands down is Sil Glyde. Its actually brake lube. Sometimes the best stuff was invented for something else. . Oh and you can get it at Advance Auto
Wow...many answers as to which is best.
White Lithium Grease
Sil Glyde Brake Grease
Silver Anti/Never Seize
KY (Vaseline) LOL
Since the bushing is rubber, I would have thought Di-electric Grease or Gummi Pfedge Rubber Lubrication.
Is heat from the exhaust or coolers a factor?
In for a more info.
KY (Vaseline) LOL
In for a more info.
Energy's bushing grease is my choice. I've also used Mobil 1 synthetic grease that has worked well.
That would've been my guess, too. I would think using a petro-based chassis grease might deteriorate the rubber/neoprene bushings over time. Never thought about white lithium grease, but I have some of that here, too. I'm contemplating adding a rear bar to my car and am watching this thread. Also have some Royal Purple GLSI No. 2 grease and some MoS² grease.
Energy's thick, sticky, grease is designed specifically for polyurethane suspension bushings.
