What is 6000 Kelvin?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,813 Likes
2015 C7 of the Year Finalist
I had a guy ask me why I put in 6000 Kelvin lights to replace the OEM 4300. I described it as the 4300 having a touch of yellow in the light where the 6000 was pure white with 8000 leaning to the blue or purple looking headlight color. After a little looking on the internet, I found this picture which I hope helps to distinguish the difference.
Elmer
Elmer
I prefer 5K myself.
Often, I find varying color temperatures between HID and LED bulb manufacturers. What one rates as 6K appears like 5K or vice versa.
Great chart for color reference.
4300K is the choice of OEM's for HID's because that provides the maximum lumen output per watt. Moving up up or down on the scale (yellow or blue, reap.) reduces the bulbs overall output of visible light. I always opt for 4300K bulbs because I want every bit of extra light the headlights can provide. My commute is 45 miles of mostly unlighted winding canyon road and those extra lumens can mean all the difference to me where safety is concerned.
Gentlemen, my post is pure information. Ya'll can use whatever Kelvin you like.
Elmer
Elmer
The 4300k optimum only applies to HID as its the natural color of the light produced. This is different for LED or halogen lamps.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Also going above 4300k violates the lighting statues in most states. I know it does here in TX. That is why the aftermarket kits have a disclaimer about the product being used off road or for show use only.
Elmer
NCM Lifetime Member
Because our cars are designed for HID lighting, you shouldn't have an issue blinding on coming traffic. Our reflectors have a cutoff shield. The issue is the trolls installing the aftermarket bulb kits in cars/trucks not designed for them. Especially when it's one of the jacked up pick up trucks the kids like to drive here in TX. They blind the daylights out of oncoming traffic.
Ahhhh. That explains the problem. I should be good to go on this and not have any issues.
Elmer
NCM Lifetime Member
10,340 Fahrenheit ; )
Sorry, couldn't resist.
NCM Lifetime Member
