are you talking about the shroud that bolts to the radiator that provides the path for the air to exit through the hood? I would assume that would no longer fit. I had to remove mine on my A&A V3 Si kit as it will not fit anymore..
It certainly does fit. Maybe you need to re-orient your charge tubes?
I have an early release of the AA kit and the charge tube is bigger than the current release version I believe. I would have to notch the radiator plastic to make it fit.
^Ah, that sucks. Maybe they can swap it out for you. I know they swapped my tensioner out for the new style for me when I had my blower rebuilt, A&A is pretty awesome that way.
