Nice article on intake valve coking
Flyingscot (02-15-2016)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,832 Likes
2015 C7 of the Year Finalist
Always interested in information but...
I see nudding?
Elmer
I see nudding?
Elmer
Sorry, it was on the subject as a whole.
Let me try the link again:
http://netwelding.com/catch_can.pdf
yub (03-01-2022)
Huh? I take it you have not read what I have been posting in other threads...all the documentation anyone, even the most un-educated could want has been provided, but if you personally disagree then by all means ignore all of this as it does not apply. This is only for those that do care to learn how these new GDI engines differ and the ways to keep them happy and alive for the duration.
Nice article, but it is still speculation and there is no scientific evidence. The theory seems sound, however there are no pictures here or on the truck forums beyond those that have been floating around which were created by wet sump spillage.
The bottom line here though is if ANYONE is not comfortable doing anything to prevent and avoid these issues, they should NOT change a thing with their car. These threads and post's are only for those that do want to avoid this and care for their investment the best way possible.
Even with port injection, oil gets where it shouldn't be. GDI just makes it worse.
But take this for what its worth.
My dads work truck GMC GDI v8. Just hit 50k miles believe me my dad doesn't care about this engine or car. Puts abuse and hard city miles all the time. Yet it runs smooth, not down on power(from what i remember), doesn't have misfires either.
I was about to put a catch can on my corvette, but then i remembered i won't keep this car long term. I came to the concuslon that i care more about buying next generation corvette with (lets hope) better PCV OEM filtration system. according to Cospeed we will see this maybe next generation GDI engines.
with the next generation corvette maybe this problem will be solved, but its going to always have some type of problem. enjoy your cars, and worry about bigger picture stuff. If it helps you sleep better at night, add a catch can.
vettetwo (02-15-2016)
If you look at the new Camaro SS with the Corvette motor you will notice a oem built in catch can from the factory. If you do a search you will see a thread on this forum discussing the modification to the LT1 engine in the 16 Camaro
COSPEED2 (02-16-2016)
dig little deeper on that "factory catch can". you will find out its not what you think. i to was excited for a fix of this problem.
GM is doing tons though to attempt to solve this. They are not just ignoring it by any means. There is no way to separate and contain the oil internally w/out also retaining the damaging combustion by-products as well, and that greatly increases engine wear and shortens engine life. I am confidant that GM and all the other Automakers will implement an external solution in the future after the self draining no end user intervention needed system patents are issued they will be on all gasoline GDI vehicles, but until then those concerned have these options to avoid the issues.
I really want to see the actual valves on some of the LT1 and LT4 engines with 20k and over miles so more can see the rate these deposits form at. So far most of the examples are on 10k and less mile cars.
I have a 2015 Denali CC with the 6.2 and on the gm-trucks forum there are pictures of a 2014 5.3 intake deposits with about 30k miles, it had a Catch Can installed at about 20k miles.
I put an Elite catch can on my Denali with about 4k miles -it know has 5k miles and this is what I emptied out of it after about a 6hr drive at 70+MPH with temperatures in the single digits.
I have the same system on my Z51, but it's sleeping in the garage right now waiting for spring.
http://www.gm-trucks.com/forums/uplo...9339_thumb.jpg
I always go back to a LS engine's valves with 140k on them and zero deposits :
and then look at any of these C7's or the trucks (and now Camaro's) at 5-10k miles to see there is no way the engine can operate as efficiently as with a clean deposit free valve. Seat of the pants is not a way to determine gradual degradation of power over time, but do a manual cleaning and the owner thinks they have a new car again as the restoration of power is instant.
Just always go back to this video and the pictures of others showing at low miles the build-up:
I will guarantee though if you take your dads truck, do a base dyno as it is, perform a manual intake valve cleaning and do a after dyno on the same day, same dyno, the power restored will shock you.
Even if this was a port injection engine, the "gunk" that these systems separate and trap keeping it out of the intake air charge, and ultimately the combustion chamber makes document able difference just from the more complete burn releasing more energy each combustion event and the reduction in knock retard due to the detonation this mix causes is reason for those wanting the best to install one of these effective systems.
In all the vehicles we have done before and after testing on the owner was doubtful in the beginning that the engine had lost power and response. EVERY single case, yet the after amazed them.
Try it and see, then no assumptions either way. Just undeniable proof. Arguing either way without proof is pointless.
