Car won't turn over - crank bolt removal
Hey guys I'm in the middle of doing an ECS install and am at the point of removing the crankshaft bolt. So far snap on and Milwaukee impacts won't cut it. 24" breaker bar broke 2 sockets and won't budge using an impact socket.
2nd to last resort is a 40" breaker bar and cheater bar (will try monday).
Last resort option is doing the starter bump method which I've used before. I actually tried it earlier but the car would not turn over. I do have the steering rack, fans, etc off the car and am stumped as to why it wouldn't turn over. Is there an input that the car looks for from something I may have disconnected that would prevent the starter from activating? I had the starter out during LT installation but I checked and looks like everything was put back properly. Any ideas? Thanks!
hi, we are in the middle of installing the innovators west 9 percent pulley on our crank and are now waiting for the little tool that locks the flexplate...anyhow why I thought I'd chime in is because hubby told me it says not to use an impact wrench because it could damage the crankshaft position sensor..
Heat with a 2' breaker bar will work as mentioned above. I think an impact would be fine too...as I recall I've seen on here where ECS mentions trying heat before the impact. Although I'm like Orange Z06 Girl...I'd stick with the breaker bar and do it by hand. I don't like the adverse effect impacts can have on some parts.
Just as an update, I finally got it removed yesterday. With heat it came off like butter! I didn't heat it until it was cherry red or anything so I didn't replace the seal. Ill keep my eye on it the first hundred miles or so. Thanks guys!
