Anyone running a front Z06 sway bar?
Has anyone swapped out the stock Z51 front sway bar to a Z06 front bar? I believe the Z06 is 2mm thicker and would add some understeer to a Z51 car?
The Z51/Z06/Z07 all share identical front swaybars; the Z51 w/MRC, Z06, & Z07 all use the same rear bar. The Z51 and Z06 use the same bushings; the Z07 has SOFTER bushings in the front (and firmer in the rear).
Rob#2 (02-13-2016)
