Fastest stock M7 quarter mile run.
I see the quickest time in the C7 fast list for base model C7 (non-Z06) manual is 11.95 in 100% bone stock form. Has anyone else been any faster than an 11.95 in a stock M7?
The fastest base model(non-Z06) C7 automatic tranny pass posted is 11.37, which is a huge difference (multiple care lengths) when compared to the fastest M7 pass of 11.95. Everyone knows the auto is faster in a straight line, but maybe there are some quicker M7 passes that have not been posted.
was out a few weeks ago, best i could do was 12.50 @ 117 spinning 3 gears
in the process of changing out rims and tires hopefully better results,
kind of regretting not getting it in automatic, =<
I am also somewhat regretting not getting the automatic as well. At first I didn't realize how much faster the automatic is in a straight line. I have also had terrible luck with almost every GM automatic I have ever owned. Even though it is faster, I see post after post on here related to issues with the A8 (i.e. hard downshifts and over-heating at the track).
I swore I wouldn't do this but at a Density Altitude of 6,400 feet I ran a 12.1 @ 118, bone stock.
With the Halltech CAI and the IW 9% overdrive pulley, at 6,600 feet Density Altitude I ran a 11.71 @ 124.8 with a 2.1 60'.
Stock Super Sport tires, with drag radials I'm sure to reach the mid/low 11's..
I now see your car is a Z06, i was thinking at first you ran the 12.1 in a base model M7.
Stock M7 with drag radials only 11.7@119. Anything faster than that would have been posted by now. I don't believe that the M7 is not slower.....you just have to put the same 60ft time as the A6/A8's. And, that's a handful.
Am in the process of that right now, I was going to buy higgs's setup but he wont take a check from me.
so the guy from wheels for less is putting me a package together.
doing
tires and wheels
torque converter
flywheel
driveshaft
axle shafts
line lock
Just to get started
doing
tires and wheels
torque converter
flywheel
driveshaft
axle shafts
line lock
Just to get started
Wow 145mph. Those are some pretty decent times for stock rims and tires. I was in San Antonio last weekend would have loved to have seen your runs.. Your mph shows some serious HP plenty enough to run in the 9's with some drag radials.
And drag radials
11.3 1/4
There just as fast they just don't hook up near as good on stock tires
I raced a auto from a roll and won him
Both stock
