GM SPO releases secondary Radiator Kit for C7
Today GM released A Secondary Radiator Kit for all C7 Corvettes with Manual transmission .Information states coolant temp can drop 25 degrees F and engine oil 15 degrees F.
Over the counter 12 month unlimited mile
3yr/36K mile dealer installed prior to purchase.
Adding the Z06 Grille to Base and Z51 will enhance cooling performance.
Part Number: 84037858
MSRP: $895.00
A little side bar note was " tracking and non competitive driving events" will not effect warranty.
Competitive wheel to wheel damage is not covered.
MSRP: $895.00
MSRP: $895.00
MSRP: $895.00
Is this for the Z06 also or does it already have it?
D.
From the release information it would be a add on accessory, and is for all C7 models Base, Z51, and Z06s with the manual transmissions. It could be a Regular Production Option or part of a package for the 2017's. I doubt it will be RPO for 2016 since the 2016 production will be winding down over the next 2 months. The information e-mail is dated 3/31 so it is possible local dealer personnel may not be aware of this package at this time. You may need a parts manager's assistance to order it. After reviewing e-mail the temperature change was based on a Z51. so it maybe be different on a Z06.
MSRP: $895.00
MSRP: $895.00
BTW - a couple of hard drives at high RPMs through my local winding roads has shown significant improvements in the coolant temps and moderate improvements with the engine oil temps.
Received 8,928 Likes
I purchased mine two months ago and installed it in my Z07. Seemed to work well at the 3 day track event I just attended but the ambient temps were only in the mid 70s. Oil temp never went above 250. The radiator adds cooling capacity by cooling the coolant after it leaves the engine oil cooler and before it gets to the main radiator.
The interesting thing about the cooler is it is closed off on the bottom when installation is complete. I don't know how air flows through it. Air flows across the top of the fins and into the intercooler but I don't see anyway for anything but leakage air to get out the bottom.
Bill
Bill
Bill
Bill
Fast forward to today's extensive 60+ miles of similar high RPM, low gear runs through the local canyons. Miles of steep downhill and miles of steep uphill. Never got higher than 3rd gear, almost always over 4000 RPM. Absolute highest coolant temp in the uphill, mostly 2nd gear sections were 212F while the max engine oil pegged at 262F. The transmission temps reached 237F now that I could run hard for longer distances.
I think, for my particular use that includes no track racing but, likely more heat producing high RPM, low gear canyon runs, I am very happy with the results.
Bill
Bill
Premium Supporting Vendor
We have them in stock if anyone is interested!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
I have a 2014 z51. I had it on the track a few times and the transmission temp went into the red zone. I thought GM was going to come out with a retro fit cooler (free of charge ) to address this issue. Did this ever happen? Or do I have to purchase this one to fix the issue ?
There are no TSB's related to transmission cooling involving C7. There is one for a P/S duct for track day performance - a customer pay add. You should discuss concern with local dealer or Chevrolet Customer Assistance. PIP5311B has information related to Track Days. IMO retrofits would be rare and on a case by case basis. GM has released several accessory kits related to cooling.
Bill
It should be no more than 2 or 3 hours. If your local dealer doesn't know Corvette's or they don't have parts personnel who are Corvette savvy then that is normally the answer you get, unfortunately.
The install instructions are in the GM Service Information (GM's online service manual) in 2016 Corvette Accessory Installation Manual under performance accessories. There is some work installing kit however there is no suggested labor time at this point. Gene's 2-3 hour labor definitely in the ball park.
Gene Culley (05-04-2016)
We are having a hot day in CA and a good one to test my secondary radiator. Temps were 85-90F depending elevations at the Sierra Foothills. At those temps I easily run my engine oil temperatures to 290F in a matter of 10 minutes of high RPM driving BEFORE installing the secondary radiator. My coolant temps were about 230F (highest) while my highest observed transmission temps (A8 with no cooler) were around 200F. The lower coolant and transmission temps were because the oil ran up so fast to 290 that the other temperatures did not have a chance to reach higher values. I basically backed off at 290 F.
However, in this application the cooler is in series with the coolant radiator as well as with the coolant that exits the engine oil cooler. The engine oil is cooled by the radiator coolant at the block-mounted heat exchanger. Thus, there are definite cooling gains for the coolant mix AND some moderate gains for the engine oil cooling as well.
This radiator has nothing to do with transmission cooling and will not effect those temperatures.
