Borla over axle gives MIL
I installed the Borla Atak over axle exhaust (11881) on my 2014 Z51 non-npp this weekend and now the MIL is coming on. This system was designed to eliminate the AFM valves by mounting them to a fake valve, but still operational to keep from throwing codes. Any idea how to get rid of it, or why it would throw codes to begin with? Will my engine grenade like owners manual states if I don't resolve it immediately?
Received 1,762 Likes
My dealer/service manage told me there would be no warranty problems by changing out the exhaust unless there were a failure directly related to the exhaust. I have the Borla x-pipe on my Stingray & Z06 plus the Borla ATAK also on the Z06. The dealer and service dept. have seen both cars and the only comment has been how much they like the way it sounds.
I am not sure of your statement "This system was designed to eliminate the AFM valves by mounting them to a fake valve, but still operational to keep from throwing codes."
Borla Atak 11881 ~
Those valves are for the AFM shown in the photo. NPP valves are located at the back of the mufflers (not shown in this photo as this system is non-NPP). Since you dont have NPP, you rightly got the single mode exhaust versus the dual mode which supports NPP. However, you still would 'normally' hook up the AFM valves to the new system. You move the stock valve actuators with wiring from the old system and bolt them into the Borla system to maintain AFM. I believe.
I have the Borla Atak dual mode that supports AFM and NPP. Both sets of factory valve actuators are moved from the stock system to the new Borla system and the valves are operational - not fake.
Dealer should not have any issue with a cat-back exhaust system. I have a full system - ARH midlength headers, cats, Corsa double helix offroad pipe, and Boral dual mode Atak exhaust system - no issues.
Borla Atak 11881 ~
On my system, it's described in this manner, "This item is used when you want to eliminate the AFM valve from your exhaust system and you don't have the NPP, dual mode exhaust option". When I spoke with the service rep, he said there are mounting bosses for the AFM valves, but they aren't hooked up to real valves. So in other words, you still hook up the AFM actuators, but they spin freely as there are no real valves to operate. Hope that makes sense.
St. Jude Donor '13-'14-'15
I have a similar car--- A 2014 A6 auto C7----- I installed a custom exhaust system--Actually eliminated both of the mufflers---Surprisingly the car is just barely louder at WOT and at P/T it is very mild---- This is the extreme of cat back exhausts--and yet I have never had a code or a reduced power mode
The only true way to insure NO codes or reduced power mode is to have it tuned----A tuner can completely delete any of those codes--permanently
The reason you get false codes with high flowing exhaust while using DOD is that the DOD system is triggered b several parameters----One being manifold vacuum --When adding a free flowing exhaust you change the P/T vacuum signal--which in return will false trigger the DOD-----Same thing happened to me----So after I tuned the ECM and completely eliminated the DOD---all the codes dis appeared I do not think you can retain any function of the DOD system with any high flowing at back system---So the best option is to simply delete it------
PS I noticed almost no reduction in fuel mileage----My belief is that GM installed the DOD system on the C7 simply to passify the gas gussler police
westman (05-03-2016)
Premium Supporting Vendor
Don't worry, the light is normal. Part #11881 was meant for those that want to eliminate AFM. That said, you will need to disable the AFM with a tune to turn the light off.
Please don't hesitate to call our customer service team at 1-877-462-6752 if you have any more questions or concerns. We are always happy to help!
__________________
Lisa Carter
Social Media & Marketing
Borla Performance Industries
lisac@borla.com | www.borla.com
Customer Service: 1-877-462-6752 (Monday-Friday 7:30am-4pm PST)
Lisa Carter
