Storing meth inside car
Is anyone else keeping a small amount of meth as a back up inside their car? I was hoping to find a safe container that fits in the cubby hole in the trunk. It is roughly 7" by 7" any ideas on a good container that would fit?
Received 1,762 Likes
I don't think it would be a good thing to do it. Just fill up your container you have it in. I don't see you running thur that much in a day are so.
Yes, I always keep a spare gallon in the hatch. I have a rubber made slealed container that is lashed down and padded. I always seem to run out of Meth at the most inconvenient times.
looks like the MSR bottles might be the ticket... just need to figure what size I can stuff in cubby hole a few of those should work. I know eventually I will forget to fill up on meth and be stuck somewhere.
re: Storing Meth inside the car
That is a lot of Meth to go through in a day. How can You do so much and still drive? Also keeping so much in the trunk... If the cops ever stop you...
Anton
Anton
I don't get how you 'run out' either.
When the low washer fluid light comes on, put more in. You figure you still have about 1/8th of a tank left when the light comes on. Even a small MSR bottle will get you almost a 1/2 a tank.
You can put 3 of the 30OZ bottles in the cubby in the back, I wrap them in paper towel so they do not clank.
The smaller bottles are easier because they are easier to pour. Do not fill them all the way. There are 2 styles and the plunger style where you have to push down and turn to take the cap off, you will spill meth on yourself if its near full.
great thanks for all the info guys... I was mainly concerned about doing a longer trip like a weekend beach trip in the vette and this seems like a good safe solution just to make sure I don't run out far from home!
I did 5,600 miles using the equivalent of 4 MSR 30 oz. bottles.
Remember the meth only comes on at WOT and usually beyond 4500rpm or so to redline.
I was think it also shot a small test shot out ever time the car started to just do a text to make sure it was working. If not working correct then the light would stay RED. Robert
