Low engine oil - add oil light
And just out of curiousity is yours auto or manual? Along with my low oil light being on, my cruise control won't stay on in 6th and 7th gear, if yours is a manual could you check yours just to see if it engages being we have the same tuner
Mines an A8 and I haven't used cruise control on any of my vehicles in like a decade lol
How to did you make out with the car? Tried calling Doug the other day to see if I can just stop by real quick, if you did get it done then did it take long? Also how are your cooling fans? Do you notice them running high all the time when the car is up to temp? Mine run low on cold start but at operating temp it seems to run at a high speed and never slow down, might just be a part of the tune, let me know, thanks
I'm going next week. I think my fans do the same thing. I'll ask him about that.
Sr.Random input generator
Quite a few issues with the tune (too aggressive fan settings, not even checking if it's a dry sump, issues with cruise control also likely caused by tune, etc.). I know he's a reputable tuner, but it at least shows he's not focused on his work.
Finding a good tuner is the hardest issue on pretty much every platform I've been to. I failed on Miata, Camaro, EvoX, and Corvettes. I've only succeeded in STi platform, but the guy had a master's degree on this very field, and later became the master tuner of Cobb Tuning. Anyhow, all I'm saying is that the OEM tune, though too conservative, is usually much better than anything we can get after market
Well ecs switched the tune to dry sump and it went away. Yesterday everything was good. Just went for a ride today and boom it's back. I thought maybe you had to drive a certain amount of distance before it goes away permanent?
Going to have to send it back to ecs. Maybe it's a bad sensor as well ?
Joetib07 (06-04-2016)
blown81bu (06-04-2016)
I feel bad for you all..so sorry for all this BS u guys are going through
I went Wednesday to have Doug re-do it and when he first did it the light went off, I started to drive away and looked down to realize my oil temp gauge stopped working, turned around and told him and he changed something else and everything seems to be working now but my cruise control still doesn't work, and it worked perfectly fine before I brought it there.
No clue, I just find it strange that me and this other guy are having the same exact issues, just makes me second guess this whole tune. I haven't had a chance to drive mine again like the other guy did but if my oil light comes back then I'm going to be pissed. My cruise still doesn't work either, for a $700 dyno tune it should be flawless.
#33
#34
I know blown81 and ECS have an issue but let's try to keep this out of this thread and keep it to the resolution. I emailed ECS and chris responded that he will make Doug aware and I have faith they will get this sorted out for me. I have been a customer for over a decade so I think they will do as they have always done for me and do the right thing.
Guess I have to get the car back to them again. That's the sucky part.
#35
#36
O boy... they ordered me a new sensor. It's not in yet but if your lights back on I'd think that's odd that it's really both sensors. Why don't you call Doug first thing Monday or call chris if you have his cell or email and tell them they need both cars. This needs to get figured out. Pm Me after you have contact with them.
Chris
Chris
#38
Chris
Chris
#39
Good luck man, let us know when you get it back how it runs, and I agree it's very strange we have the same issues.
#40
Issues
I don't think it has anything to do with sensors, what are the odds that we are having identical issues with our sensors, I know you never use cruise control but can you do me a favor and try yours, see if it works in 5,6,7,8th, I'm just curious to know if yours isn't working either, from what I hear but hopefully I am wrong is that the sensor for dry sumps are inside the pan and have to remove the pan and is kind of a pain in the a**. It has to be something in the tune.
