C7 Z06 front brakes for $1,150 + pads!
#101
J56 is the three letter code for these brakes.
The rear calipers actually look identical with piston sizes, etc., besides the offset, and the pads are also identical. Looks like the difference is limited to the heat capacity. We could probably just change fronts and would be OK, since ee don't have 650 HP : )
I don't think you'll need Z06 brakes if you'll not use your car at the track. If you'll go to track, though I'd highly recommend it to have consistent brakes. The stock brakes could be overwhelmed at the track, especially on R compound tires, based on others' experience.
#102
Sr.Random input generator
Regarding the pin kit, they are the same as your rear Z51 pins, which is what I used on my conversion.
ya3coub (05-13-2017)
#103
On my z51 brakes, I have been switching back and forth between street and track pads for each track day. Any idea on how many times I pull the pins out before it is a good idea to replace them?
#104
Honestly, I never needed to replace any of the pins on any of my cars. I'd hope that they'd last the life of the car? Even the caliper rebuild is pretty much (optionally) the pistons and inner/outer seals. One benefit of an overkill rear brake is that you'd likely never need to rebuild it, either : )
#105
X25: Your track build and z06 brake build have been invaluable. I know it has taken a lot of your time to document and comment on these. I know you have been told this before but I really appreciate it!!!!! I want to get the most out of my Z51 and your threads have been invaluable. THANKS!!!!!
X25 (01-14-2017)
#106
Ok. That makes it easy then and I don't have to worry about finding new ones.
tiborrules (01-14-2017)
#107
Yup, love following your build.
As soon as my warranty is up, I'll doing the same.
X25 (01-15-2017)
X25 (01-15-2017)
#109
Interesting thread, I have been tracking the Wilwood kit for 2 years now, and I have to say I think it is a better set up than this one. Your parts will be about the same, but the rotor that comes with that kit is superior to this rotor.
The Caliper is smaller and lighter as well, their are no dust seals, which will fail on the track and the pads are very inexpensive.
I have driven them at some of the fastest tracks in America and lap after lap they are awesome and never fade, the best feeling brake pedal I have ever driven.
Those Brembo's are huge heavy rotors and the fact that the front rotors are the same part number means they are not veined directionaly.
I would go Wilwood, Stoptech or AP, just my .02 cents.
#110
I've used both Wilwood and StopTech kits, as well as stock Brembos on many cars. You're right that the stock front rotors are not directionally vented, which is a big issue, but they're not heavier. Nevertheless, I've since switched to Girodisc, which are not too expensive, and ring cost is not too bad.
Moving on to calipers, though, Wilwood calipers have been the worst in my experience. They're very flimsy, and they do flex. That small size becomes an issue. In comparison, StopTechs have been the stiffest calipers I've used. They're 2 piece, but still feel stiffer than the mono block OEM style Brembo calipers.
Wilwood has recently responded to these criticisms, and released their aero calipers. These are much stiffer than their older stuff, but they do have an unremovable mid bridge, which means you have to remove the whole caliper to just change pads - unacceptable in my opinion (I'm lazy).
I think Z06 calipers are great and the system can easily be made competitive to BBKs with better rotors (what I did). In my opinion, Wilwoods would be a downgrade - either due to much weaker calipers, or due to an impractical design that forces you to remove calipers too many times.
#111
Former Vendor
To an extent I would agree with some of the comments above regarding the Wilwood calipers. Having been a dealer now for 24yrs I've seen various levels of product released, altered and redesigned.
The early, and still popular, kits were produced with smaller Billet Super Lite Six's which were simple machined billet extrusion. These were then replaced later with a move to more larger model rotor with the W series- which retained the very popular top loading feature the company was known for. The W series did very well on a wide variety of uses up to an including a lot of open track users. Some still felt there was a need for improvement however.
A few years ago the W series morphed (in part due to military contracts) into what is now the Aero line of calipers. This was one of the first closed bridge models the company had ever produced. While some track guys shouted it was a huge loss to the ease of pad change, others rallied behind the fact that they now had a caliper equal to or better than some other product on the market. And made in the US at a price point the others cannot touch.
Also a few years ago now the entire BSL line was upgraded. Today's smaller kits (ie. smaller kits with lighter and smaller calipers geared more towards the street user) are fully stress flowed forged ingots and no longer bar stock with the problems related to grain structure. Thes bodies are significantly heavier just picking one up. The have addressed the stiffness and flex issues to the point that they are no internal crossovers and no longer have the external pipe- still found on a number of other manufactures. So much so that even the top shelf GN6R winning caliper in TA is now internal. That says something for the integrity of the product and the belief it in as high stress and flex would lead to leaking issues...
Overall the entire line has been improved and redesigned. AND yet the price point has been the same or now even LESS than it was some years ago! Still some folks shop the wrong product for the use- that's not a manufacture problem, that's a user problem. I'd stress everyone look at their needs and make a purchase you're comfortable with.
Hope that bit of history helps shed some light
#112
GM states they don't fit on base/Z51 wheels. I'm guessing it probably just needs a very small spacer, perhaps a few millimeters? The wheel's size is definitely enough; it must be the offset.
I'm also going to order track wheels, so this is not an issue for me. I'm leaning on CCW's TS12 monoblock wheels, and CCW said they should clear the Z06 brakes. They're very secretive on their offsets until the payment, but my calculations show that the following should fit well:
18x10 ET56
19x11 ET73
We'll see!
18x10 ET56
19x11 ET73
We'll see!
#113
X25 Thank you for starting this killer thread. Huge help!!
X25 (04-01-2017)
#114
can we not use our old hose and hardware kits?
also, has anyone found a cheaper price than $600 for a pair of rotors?
#115
I installed front s.s. lines as I have heard that the lines on for the z06 are about a 1/2 inch longer but don't know that for sure. Changing out the front lines is a pain. If I did it over again I would try using the original lines but have a set of s.s. just in case. After you hook them up turn the steering lock to lock to make sure they are long enough.
The end product is worth it!!!! I had a track day with the z06 brakes and my car stopped great!! Definitely and improvement if you track your car hard. My car has a procharger on it so I hit higher speeds down the straights.
village idiot (05-11-2017)
#116
Yeah, I thought the weight savings would be bigger. Only 1lb up front.
Rears are incredible- 8lbs EACH
#117
FRONT: It's hard to save weight when even the OEM is 1-piece, but you should also note that the Girodisc unit (or the DBA OEM-replacement ring for that matter) are DIRECTIONAL, and will allow much better cooling. Even for this very reason, switching is very appealing. To save $$$, you could also just switch to DBA rings when yours are done, but please note that they are a little bit heavier than OEM.
REAR: The savings with switching to Girodisc over Z06 rears is huge! The reason is that the OEM 2-piece has an iron hat to accommodate heavy hand brake use, while Girodisc unit has a simple aluminum hat (would've preferred an iron liner there to be honest). So, if you are OK with not drifting with your Corvette, you should switch. IIRC, Z06 rear rotor weighs 24.8 lbs, while the replacement Girodisc unit is 16.7 lbs.
From my build thread:
Girodisc C7 Z06 rear rotors look beautiful. As you can see, the provision for the hand brake is aluminum. This means no national drift championship for me; oh well.
... and they are incredibly light at 16.7 lbs! FYI, stock Z51 rotors are at 18.1 lbs, and stock Z06 rotors are at 24.8 lbs!!!!!! These might actually even be lighter than the CCM Z07 rear brakes since they probably have a steel hat for handbrake, too; will check on that.
Looking forward to receiving the LG coilovers and sway bars + end links!
#118
Did you just use z51 rear calipers with the z06 rotors?
#119
I was look at the lines, do you need them if you have a Z51?
I know your car was not a Z51 but all the lines I look at say C7 Z06/Z51 for fitment.
I'm placing my order right now but do not think I need the lines.
