Launch control - 2015 7 speed
They showed us at Spring MountIn but I must have missed a step.
What are the correct steps to engage launch control.
2015 Z51 MRC 7sp.
2015 Z51 MRC 7sp.
I couldn't get it to work for the longest time either. Try hitting the brake pedal HARD before you romp the gas pedal. That is what my problem was.
2016 MRC 7speed
2016 MRC 7speed
Same with the gas pedal, you need to pound that thing and just trust that you did the process right and the rpms will stabilize. If the tach shoots past 5k, then get off the go pedal and try everything again. All pedal movement needs to be quick. Hard on the brakes with no movement whatsoever, stomp the gas, dump or side-step the clutch, keep it straight.
